Plexamp Recently added not in correct order
Evening.
Having an issue with plexamp for the last few days in that my recently added music section does not work correctly.
I’ve attached some images that show the correct order on the plexamp homepage, but then the incorrect order if I expand this.
For comparison using the standard Plex app the album’s are in the correct order.
I saw this Friday, and playing with it a bit it seems that it was simply ignoring the designated sort order, no matter what you choose.
However, when I came here to report it today, I found that I couldn’t reproduce the problem. So it’s one of those maddening intermittent bugs.
(I’m running the latest release 3.3.1 on Android 11, on a Pixel 2.)
That is worth adding actually - I’m running 3.3.1 on a Samsung S20+.
this was a regression on 3.3.0, which was fixed in 3.3.1.
How does this explain my post above stating it happens on 3.3.1?
it doesn’t, i don’t have an explanation for that.
AH sorry, I must have read it wrong. I took it as you saying it was fixed.
it is fixed, so i don’t have an explanation of why you’re still seeing it :grimacing:
