Plexamp search?
Why does a search term “Funky” not find any of the versions of the track “Funkytown” that I have?
Does partial word search not work? Seems kinda limited if typing correctly a decent chunk of a word does not find words that contain the term…especially when it’s a track title
If you have at least 3 tracks which have “funky” as a separate word in their title, these will appear first because they match the search term better.
However, if you tap on the “Tracks” header, you will get a longer list of search results which should contain partial matches as well.
Thanks… It was that little arrow for more which was an unexpected search experience.
That worked :smiley:
