Plexamp sleep timer not working properly
I’ve had this problem for a while, and I think I’ve finally figured out whats going on.
When Plexamp is in the background the UI is paused, it seems that this is pausing the countdown as well, because when Plexamp is brought back to the foreground the UI updates again and music immediately stops as well (if the sleep timer has run out).
Do you have an android phone? If so, make sure you don’t have any battery save enabled
Ah, sorry. I forgot to mention this happens on my Windows laptop. :sweat_smile:
