Plexamp stream doesn't stop
Everything that I use Plexamp in Windows to listen the music from my library. I’ve discovered that stream is still active after, I’ve stopped Plexamp and closed it.
I’ve tried to stop the stream in the dashboard, but it doesn’t show any kill button.
The only way to stop is rebooting the server.
I am using the latest version PMS in synology.
If I use the web application, I don’t have problems.
There is no reason for concern. It is not really streaming.
Good to know. Thank you.
