Nest mini supports Opus, Plexamp app supports and plays on my phone, but when I try to cast it, it doesn’t work? Why? Any way to make it work?
can you be any more specific? does the Nest Mini show up on the cast list? what happens when you try to select it? can you post app logs?
Here’s a link to the behavior of the app when I try it and logs and the opus file I’m trying to cast:
Playback stops/locks and you can’t continue it in summary.
Jan 25, 2021 12:28:20.590 [Javascript] INFO - Cast: Successfully connected to f5fd1e9572e822b0e10210968d25573c.
Jan 25, 2021 12:28:20.650 [Javascript] INFO - Cast: unknown player state.
Jan 25, 2021 12:28:20.660 [Javascript] INFO - Cast: Got event for state stopped.
Jan 25, 2021 12:28:20.681 [Javascript] INFO - Cast: unknown player state.
Jan 25, 2021 12:28:20.733 [Javascript] INFO - Cast: unknown player state.
Jan 25, 2021 12:28:20.741 [Javascript] INFO - Cast: unknown player state.
Jan 25, 2021 12:28:20.750 [Javascript] INFO - Cast: unknown player state.
Jan 25, 2021 12:28:22.742 [Javascript] INFO - Cast: Asked for state (now: playing)
Jan 25, 2021 12:28:29.485 [Javascript] INFO - Cast: Sending message 'PAUSE'.
Jan 25, 2021 12:28:31.497 [Javascript] INFO - Cast: Sending message 'PLAY'.
Jan 25, 2021 12:28:34.526 [Javascript] INFO - Cast: Sending message 'PAUSE'.
Jan 25, 2021 12:28:39.155 [Javascript] INFO - Cast: Sending message 'PLAY'.
Jan 25, 2021 12:28:41.213 [Javascript] INFO - Cast: Sending message 'PAUSE'.
Jan 25, 2021 12:28:42.637 [Javascript] INFO - Cast: Sending message 'PLAY'.
Jan 25, 2021 12:28:55.593 [Javascript] INFO - Cast: Sending message 'STOP'.
Jan 25, 2021 12:28:55.600 [Javascript] INFO - Cast: Disconnecting.
Looks like the device isn’t responding
Do you get the same behavior when casting from main Plex app e.g. or web?
Same behavior from main plex android app.
Nest mini doesn’t show for casting on web.
then it seems like a chromecast issue, so you’ll probably want to post about it in that sub-forum. do you see the issue with all media, or specifically only with Opus as the topic implies?
mp3, flac casted fine to best of my memory. I don’t have many other files with different codecs in my audio library.
I don’t see a “chromecast” sub category under all categories tab. Do you have a link of the category you mentioon?
i’ve passed the report directly over to the team. if you can provide a download sample i’ll pass that over too
Thnx.
I’m not sure what download sample refers to?
a file which is exhibiting the issue
It’s inside the folder I’ve shared previously:
ah, apologies, i wondered what that file was
