Plexamp unable to work on Android 6
I have the same issue as PlexAmp 3.1.0 - Android 6 - Never Ending Song Skip till phone crashes
Tested on Nexus 7 2013 and Galaxy S5, both on Android 6.01. Plexamp would play once or twice when Plexamp was first installed, then subsequently it’ll just continue to skip through all tracks and not playing back anything.
i think what we found is that some of the audio plugins didn’t work on some older devices. can you post debug logs?
Thanks for looking into this. I’ve attached the logs here:
(File removed)
The weird thing is - the playback worked during initial app installation and failed subsequently. Removing cache, uninstalling and reinstalling plexamp doesn’t seem to recover the failure.
Dec 06, 2020 11:30:09.587 [0x9edbf930] ERROR - BASS: Error [plugin = BASS_PluginLoad(file, 0)] - 2
Dec 06, 2020 11:30:09.590 [0x9edbf930] ERROR - BASS: Error [plugin = BASS_PluginLoad(file, 0)] - 2
Dec 06, 2020 11:30:09.591 [0x9edbf930] ERROR - BASS: Error [plugin = BASS_PluginLoad(file, 0)] - 2
Dec 06, 2020 11:30:09.592 [0x9edbf930] ERROR - BASS: Error [plugin = BASS_PluginLoad(file, 0)] - 2
Dec 06, 2020 11:30:09.593 [0x9edbf930] ERROR - BASS: Error [plugin = BASS_PluginLoad(file, 0)] - 2
all the audio plugins are failing to load for some reason.
