Plexamp - volume control issues
Thanks for adding the volume control!! Do you think you could update the other thread that talk about the volume control where the answer is “use control+alt+arrow up or arrow down”. When doing a quick search on google, those results pops up first, where in fact this thread here we have a better answer.
Also, in windows, it seems the default shortcuts are cmd+alt+up or down, but it doesn’t work because windows has a ctrl not a cmd keyboard button.
I wish I had found this thread earlier in my google search.
Thanks, I love plexamp and the shortcuts
On windows I can’t do ctrl+alt+pg down or page up. The resulting shortcut is registered as Control+Alt+"
I tried on 2 different keyboards, and got the same results.
Try CTRL+Alt+Up (which means the cursor key “up”)
we’ll have support for mapping the page up/down keys in the next release.
My question is related to volume control so i thought it was the right thread.
I am using a Universal Audio, Apollo, as my Audio interface, I re-routed all my audio system in the mac ‘audio midi set-up’, to one of Universal Audio virtual channels, so I can control all my audio system with a fader, mute, fx inserts… from the Universal Audio Console app.
When I use pretty much any application on my macbook, the audio go through the virtual channel, but not with the Plexamp mac app, which is a bit annoying. The sound goes through but it goes straight to the main output and not via the virtual channels.
Any idea why this is the case?
Is there something specific about the Plexamp mac app is done that explain this, or the cause is to be find elsewhere?
Thanks!
