PlexAmp Win7 playback stutters
#1
Hello,
I use plexamp at work on my win7 pc over internet connected to my local pc. Network upload of my internet connection is 667kbit/s
Playing starts fine but after a while playback stutters. If I switch to a new title it starts ok but than stutters again.
Playback from browser is fine all the time on same machine.
Best regards,
Stefan
Edit: seems to be a problem releated to this topic:
https://forums.plex.tv/discussion/300108/plexamp-bandwidth-usage
#2
I’m seeing this same issue. I am also using a Windows 7 PC at work. Web client playback never begins stuttering.
#3
Experiencing the same issue with plexamp 1.0.2 on MacOS 10.13.3. Seems to be related to buffering, because pausing the track for a few seconds and then playing will usually resolve the issue (for that track).
#4
There’s clearly something we’re missing, as many of us listen all day, and never experience this issue… we’ll keep reading and try to figure out what the common factors are.
#5
I’ve never experienced this problem at home on an iMac (local playback), but it happens 100% of the time at work (remote playback from the same library). For me, it begins stuttering anywhere from 1-3 hours into a continuous, non-paused playback session. Plexamp also seems to disconnect from the playlist until restarted. Sometimes after restart it will pick up the playlist automatically and other times I have to choose a playlist again. Is there a log that might point to what’s happening?
#6
OK, most of the time I’m locally playing back, so that might indicate some of the difference. Definitely check Server.log and Application.log for anything suspicious. Also curious as to whether:
  • If you stop and start a new PQ, does that fix?
  • If you kill the mpd process and then start a PQ, does that fix?
Those two questions should help identify the culprit.
#7
I finally had time to do some testing this morning.
  • While stuttering, if I stop playback and begin a new play queue, the new play queue also stutters immediately.
  • While stuttering, if I kill the mpd.exe process, the play queue ends and mpd.exe is respawned. If I begin a new play queue (without restarting Plexamp), the new play queue also stutters immediately.
So far, the only way I’ve found to eliminate the stuttered playback (for a while) is to completely close and restart Plexamp.
As for the logs: At the time playback begins stuttering, Server.log seems to continue with normal debug playback messages every 6 seconds (HTTP: Issuing request to https:// … /timeline?state=playing&duration=…&time=…).
Application.log might provide a clue, though: At about the time stuttering began this morning, there were warning messages about loss of connection to my Plex server (an iMac) for more than 5 seconds. The log also listed connection failures for my other Plex client devices (none of which had the Plex app open).
UPDATE: The next time playback began stuttering, there were no messages about loss of connection. After closer inspection, I believe the connection warning messages occur after restarting Plexamp, not at the time stuttering begins.
@elan, I can PM the logs to you, if it would help.
UPDATE 2: The next time playback began stuttering, I was tailing both logs and looked at them immediately. The Application.log added nothing to signify a problem. Server.log didn’t either – it just continued to add “Issuing request” messages every 6 seconds.
UPDATE 3: And the next time playback began stuttering, I paused the playback, waited a few seconds, and pressed play again. The play queue then exited completely and waited for me to select another playlist, artist, etc.
Server.log file issued these errors and warnings:
Feb 26, 2018 15:13:24 DEBUG - GET /player/playback/pause?commandID=3219 200 2 - 0.724 ms
Feb 26, 2018 15:13:24 DEBUG - State changed from playing to paused
Feb 26, 2018 15:13:24 DEBUG - HTTP: Issuing request to https://[ip address]:13556/:/timeline?state=paused&duration=311928&time=269653&playQueueItemID=132710&key=%2Flibrary%2Fmetadata%2F42068&ratingKey=42068&playQueueID=5073&playQueueVersion=1&containerKey=%2FplayQueues%2F5073&hasMDE=1
Feb 26, 2018 15:13:33 DEBUG - GET /player/playback/play?commandID=3226 200 2 - 0.586 ms
Feb 26, 2018 15:13:37 ERROR - [MPD] Error connecting:Error: write ECONNRESET
Feb 26, 2018 15:13:37 DEBUG - Lost connection to MPD, reconnecting
Feb 26, 2018 15:13:37 ERROR - [MPD] Error getting status! This socket is closed
Feb 26, 2018 15:13:38 INFO - [MPD] Connecting...
Feb 26, 2018 15:13:38 INFO - [MPD] Ready!
Feb 26, 2018 15:13:38 DEBUG - GET /proxy/file.mp3?source=[alphanumeric string]&endpoint=%2Flibrary%2Fparts%2F44395%2F1236048802%2Ffile.mp3%3Fdownload%3D1%26X-Plex-Client-Identifier%[alphanumeric string]%26X-Plex-Session-Identifier%[alphanumeric string] 200 5924196 - 174.374 ms
Feb 26, 2018 15:13:38 DEBUG - PROXY: Stream got closed after sending 5422044 bytes.
Feb 26, 2018 15:13:38 DEBUG - State changed from paused to stopped
Feb 26, 2018 15:13:38 DEBUG - HTTP: Issuing request to https://[ip address]:13556/:/timeline?state=stopped&duration=311928&playQueueItemID=132710&key=%2Flibrary%2Fmetadata%2F42068&ratingKey=42068&playQueueID=5073&playQueueVersion=1&containerKey=%2FplayQueues%2F5073&hasMDE=1
Feb 26, 2018 15:13:38 DEBUG - PlayQueue: Skipping audio update for NaN, it was too old.
Feb 26, 2018 15:18:24 WARN - [POWER] Turning power off!
`Feb 26, 2018 15:18:38 WARN - [POWER] Turning power off!``
Application.log looks uninteresting in the same time period:
Feb 26, 2018 15:13:24.111 INFO - POWER: Enabling power save mode.
Feb 26, 2018 15:13:24.129 INFO - Requesting /player/playback/pause?commandID=3219 from player Local.
Feb 26, 2018 15:13:24.129 INFO - HTTP: Issuing request to http://127.0.0.1:20000/player/playback/pause?commandID=3219
Feb 26, 2018 15:13:33.303 INFO - POWER: Disabling power save mode.
Feb 26, 2018 15:13:33.316 INFO - Requesting /player/playback/play?commandID=3226 from player Local.
Feb 26, 2018 15:13:33.316 INFO - HTTP: Issuing request to http://127.0.0.1:20000/player/playback/play?commandID=3226
Feb 26, 2018 15:13:33.364 INFO - POWER: Enabling power save mode.
Feb 26, 2018 15:13:38.342 INFO - HTTP: Issuing request to https://[ip address]:13556/hubs/sections/5?count=4&includeLibraryPlaylists=1&includeStations=1&excludeFields=summary
Feb 26, 2018 15:13:38.343 INFO - POWER: Enabling power save mode.
After the play queue was flushed when attempting to pause and play, the stuttering went away without having to restart Plexamp. At least temporarily.
UPDATE 4: Very similar Server.log messages were produced the next time stuttered playback began, and pause/play again flushed the play queue, allowing playback without stuttering for a time.
UPDATE 5: Same thing again. This is very repeatable. Plexamp is losing connection to MPD (the socket is getting closed).
UPDATE 6: I took a look at the log.log file in %appdata%\local\programs\plexamp and noticed that when the stuttering begins, log.log starts filling up with 3-6 entries each second repeating the replay gain until playback is stopped:
Feb 26 15:13:22: replay_gain: scale=0.904690
Feb 26 15:13:23: replay_gain: scale=0.904690
I tried to remove logging by editing the mpd.conf file, but everything I tried resulted in Plexamp not starting playback at all (even after a restart). I guess the logfile is required.
