Plexamp working great on odroid-c4 (raspberry pi alternative)
Just wanted to share that plexamp works great on the odroid-c4 … unlike the raspberry pi, these are currently available for purchase :slight_smile:
The C4 seems comparable to the pi4, and it has some nice features that make it a good fit for streaming music (fanless, eMMC storage support, separate connector for an i2s dac hat, etc.)
Currently just running plexamp on the ubuntu 22.04 minimal image provided by odroid (easy to get the right version of node, and to enable support for odroid’s hifi-shield+ dac hat, which I’m also using) … I’m sure there are other OS options that would also work
https://www.hardkernel.com/shop/odroid-c4/
https://www.hardkernel.com/shop/hifi-shield-plus/
My current favorite is the 4GB NanoPi R4S. Doesn’t have WiFi or hat capability, but I prefer to hardwire mine and am using a digital amp with USB input. Really solid metal case.
Hi Elan,
What OS are you using?
Armbian. Works great.
