PleXBMC client for XBMC
I'll check it out.
Force views is very much a workaround for a missing XBMC feature - which is why it's a little clunky. I'm always looking for ways to make it better.
Thanks for the latest version. It is ultrafast (what have you done to it? :) ) and working problem free so far. I'm using fixed server address so I guess it helps to speed things up but nevertheless this version is faster for me than 3.1.2 I was using before.
As for the skin problems I'm puzzled a bit. I use Quartz.Reloaded and Quartz-plexbmc (go figure:). I do not have problems with different views not being remembered.
I.e.  - I have adults and kids section under Movies. Adults open up panel view (after filter menu), while kids section ends up in grid view. This works for me in both skins and I DO NOT use forced views at all.
It's working perfect for me....in the case of TV Shows I use: Panel, List then Media Info....love it...
Ehhh, is it just me getting script errors since today's update? Happens with any media when I hit play. It seems to be a playlist error (cannot find the media). I've tried rebooting both the server (latest version on Windows 7), the NAS and the client (Openelec latest running plexbmc). Everything was hunky dorey (for a week or so at least) up until today sometime when I suspect the plugin autoupdated to the latest version. Not sure if this is something silly, I've included a bit of the debug log that seems to contain the error. Let me know if I need to upload any full logs or anything. Any help greatly appreciated! For now, I've reverted back to the plex Windows 8 app on my laptop, and also the Samsung TV plex app, both of which are working fine.
20:05:10 T:2683284288  NOTICE: <?xml version="1.0" encoding="UTF-8"?>
20:05:10 T:2683284288  NOTICE: PleXBMC -> getURL: ====== XML finished ======
20:05:10 T:2683284288   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                             - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                            Error Type:
                                            Error Contents: invalid literal for int() with base 10: 'sd'
                                            Traceback (most recent call last):
                                              File "/storage/.xbmc/addons/plugin.video.plexbmc/default.py", line 4077, in
                                                playLibraryMedia(param_url,force=force)
                                              File "/storage/.xbmc/addons/plugin.video.plexbmc/default.py", line 1707, in playLibraryMedia
                                                streams=getAudioSubtitlesMedia(server,id, full_data)
                                              File "/storage/.xbmc/addons/plugin.video.plexbmc/default.py", line 1616, in getAudioSubtitlesMedia
                                                if int(media_details.get('videoResolution',0)) >= 1080:
                                            ValueError: invalid literal for int() with base 10: 'sd'
                                            -->End of Python script error report<--
20:05:10 T:3016496896   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.plexbmc/?url=http%3A//192.168.1.9%3A32400/library/metadata/18737%3Ft%3D9262525362&mode=5]
In case you did not know - there’s a rollback button in addon settings that allows you to roll back to previous version of script. It will work only if script was installed via “add from zip” or via repository. It will not work for copy-paste installations.
Btw, for those handy with git - I’ve proposed patches for Quartz that should enable posters for tv on shelf and add support for banner views.
For those that would like a different skin - you could try quartz.reloaded from my git. Reloaded has no recently added shelf or pvr support (yet).
Yes, sorry - it's a bug.  I've fixed it and am just about to push out an update to fix it.
Ah cool, I can stop troubleshooting it so! Thanks
@pecinko for some reason my installation of xbmc does not have the rollback function enabled for any of my plugins, even though they're all installed by repository. The option is greyed out. Thanks for the suggestion though.
Just pushed it out, so should be available.  Not exactly sure how often XBMC checks for updates, but if you force a check it should appear.
EDIT: Updated all links to point to new P3.1.5 and H3.1.3 releases
I think its more of a problem for TV shows than movies.  The view is reset for each individual show and season, so if you change one TV show, that change doesn't happen for all TV shows.
For movies, a view for "All movies" isn't carried over to "Recently Added" or "Unwatched".
The forced views use "Container.SetViewMode(%s)" to switch the view from the plugin.
OK, after your comments I looked around all the settings to understand what happened and I found why "panel view" didn't worked for me with quartz.
On quartzv3.plexbmc skin, I had to activate the option "Grid & Fanart view modes" in settings/skins !
Now the strict skin settings are working well for me.
May be it's better to activate this option by default ?
Thanks again for your work, plexbmc is such an amazing thing :)
Btw, for those handy with git - I've proposed patches for Quartz that should enable posters for tv on shelf and add support for banner views. For those that would like a different skin - you could try quartz.reloaded from my git. Reloaded has no recently added shelf or pvr support (yet).
i'm loving the quartz.reloaded skin. But atm, I use quartzv3 because of the lack of plex feature on the main menu.
I would like to see the recently added or on deck movies / tvshows over the section's names.
Is it yet possible or planned ?
Thanks !
ps : anybody know if we can use aeon nox skin (or other highdesign skins) with plexbmc plugin, integrated of course, may be with somes favorites settings, etc... ?
Hi Pecinko,
quartz.reloaded looks nice, so you think you'll add "OnDeck and Recently Added', "plexbmc support" and Live TV?
If yes it would be a nice skin indeed...
EDIT - I see it is plex enabled...nice. A few things would be really nice:
  1. Images from my TV Shows/Movies/Music render as backgrounds (cycling) as selected from the said sections....or even global slide show
  2. Strict views supported
  3. Some sort of OnDeck/Recently added or if this is a little hard to do then under each main menu having submenu's that one can add/remove/edit to their liking (like you have in the Add-Ons menu). For example I like to have All, Unwatched for TV shows and All, Unwatched and Recently added for movies.
  4. My sound clicks for menu selections and just general clicks
All I can think of now, however if you had those things it's be really cool in my view...thanks for all your efforts Pecinko...nice work.
-SM
Aha, now I get it.
XBMC views problem is two fold :)
a) they are not remembered for some add ons at all. Or they are, but setting gets reset on addon update :)
b) What are you describing above is that they get saved for every TV Show separately and that is considered a feature of XBMC. Don't know if there is advanced setting that could turn this off.
In case of recently added items I like it as I prefer "Big Panel" view with longer synopsis for it, while using different views for Movies.
Hi Pecinko,
1. Not sure it is possible without help from Hippojay and even then - I have quite a few low-res fanart images.
2. I'm affraid this would be up to Hippo to decide
3. On deck and recently added is not a problem skin wise. Problem is that I have not decided yet about home page layout.... and that RA/OnDeck items would be mixed as they are currently served per media type rather than per section. Hippo said he might separate them but I did not want to bother him with it at that time.
4. This is not possible but you can always change to built-in ones or overwrite skin supplied sounds with your own.
PVR support... maybe, if I manage to get working backend again. To be honest I'm not sure how many pexbmc users would use it - you may end up using reFocus or PHT and PVR is not a minor skinning task :)
Hippojay
do you have any suggestions or personal preferences regarding Reloaded? Did you find any of proposed Git patches useful?
Aha, now I get it.
It's just one of those thinsg that was never added.  There is a bit of a thread about it over here with some possible solutions: http://forum.xbmc.org/showthread.php?tid=154805
Hippojay
I haven;t had a chance to look at skins at the moment.  I'm current just adding in some basic cache functionality, and need to look at remote music playback with the Helper.  But once done i'll definitely start looking into skins again.  Perhaps this weekend or over Easter.
Yay! Go skin dev :slight_smile:
I use Aeon Nox with plexbmc. I turned off the xbmc "movies/shows/music/pictures/etc" main menu items and use custom ones linked to items plexbmc. I did this by creating favorites from the plex items. You cant (or i couldnt figure out how) create a favorite from like "Movies" but you can from "All items" under "Movies". Even ones like "recently added" or "on deck" can be added to favorites. Then within Aeon Nox, the favorites can be added as main or sub menu items. You can then seamlessly mix in the Plexbmc menus with the xbmc menu items like Programs (so you can run xbmc add ons) or LiveTV/PVR.
First of all: thank you hippojay for a marvelous job.
I have a somewhat out of the ordinary setup that used to work fine until recently. I'm running PMS (09.7.17.469) on a Mac Mini (OSX 10.6.8). I have a MacBook (Black, 2.4GHz, OSX 10.7.5) with XBMC 12.1 and PlexBMC 2.0 with Helper, that works beautifully. But I also have an iBook G4 (OSX 10.5.8) that runs XBMC 11.0 and PlexBMC 2.1. In prevous version of PMS and PlexBMC that one worked too, but now it lists only the categories in PMS, and either does nothing after that (when the static IP adress of the Mac Mini is selected), or gives an "Unable to connect to host" message (when Bonjour is selected).
The categories are listed with the name of the PMS server in front of it, which is not so on the MacBook. (i.e. Mac Mini Server:Movies). (*edit* not when I leave user name and pw empty for MyPlex. But still no listing or anything beyond that. Channels do work, though...)
The XBMC network settings on the iBook are:
UPnP server: off
UPnP rendering: off
Webserver: on
Port: 8080
user name: provided (*edit* empty now)
password: provided (*edit* empty now)
remote actions: off
Zeroconfig pub: on
Airplay: off
The skin I use is either Confluence.plxbmc (current) or SLik (most other skins don't play nice with the limited graphic capabilities of the iBook).
Does anybody know what I am doing wrong?
