May i know if it is possible to stream movies without the hdcp check. currently i only have access to a monitor with vga and atv refused to play any HD movies because of the hdcp.
for movies/tv series purchased from itunes store, if i chose the video output as 480p, then i can watched them without issue. So is it possible to stream movies from plex connect without the hdcp check?
thanks a lot if anyone has insights on this
No.
