Plexconnect Docker (and unRAID)
I`ve also installed unraid-plexconnect through the Community Applications, but I get the “Trailers not available. Try again later.” message on the ATV.
Can you help?
This is the log:
*** Cloning PlexConnect ***
Cloning into ‘PlexConnect’…
*** Generating certificates ***
Generating a 2048 bit RSA private key
writing new private key to ‘./trailers.key’
*** Setting userID and groupID ***
Starting PlexConnect
chown: unknown group
Feb 02,2018 21:10:53 PlexConnect: ***
Feb 02,2018 21:10:53 PlexConnect: PlexConnect
Feb 02,2018 21:10:53 PlexConnect: Press CTRL-C to shut down.
Feb 02,2018 21:10:53 Settings: add setting enable_plexgdm=True
Feb 02,2018 21:10:53 Settings: add setting ip_pms=192.168.178.10
Feb 02,2018 21:10:53 Settings: add setting port_pms=32400
Feb 02,2018 21:10:53 Settings: add setting enable_dnsserver=True
Feb 02,2018 21:10:53 Settings: add setting port_dnsserver=53
Feb 02,2018 21:10:53 Settings: add setting ip_dnsmaster=8.8.8.8
Feb 02,2018 21:10:53 Settings: add setting prevent_atv_update=True
Feb 02,2018 21:10:53 Settings: add setting enable_plexconnect_autodetect=True
Feb 02,2018 21:10:53 Settings: add setting ip_plexconnect=0.0.0.0
Feb 02,2018 21:10:53 Settings: add setting hosttointercept=trailers.apple.com
Feb 02,2018 21:10:53 Settings: add setting port_webserver=80
Feb 02,2018 21:10:53 Settings: add setting enable_webserver_ssl=True
Feb 02,2018 21:10:53 Settings: add setting port_ssl=443
Feb 02,2018 21:10:53 Settings: add setting certfile=./assets/certificates/trailers.pem
Feb 02,2018 21:10:53 Settings: add setting allow_gzip_atv=False
Feb 02,2018 21:10:53 Settings: add setting allow_gzip_pmslocal=False
Feb 02,2018 21:10:53 Settings: add setting allow_gzip_pmsremote=True
Feb 02,2018 21:10:53 Settings: add setting loglevel=Normal
Feb 02,2018 21:10:53 Settings: add setting logpath=.
Feb 02,2018 21:10:53 PlexConnect: Started
Feb 02,2018 21:10:53 PlexConnect: Version: 0.5-dev-161017
Feb 02,2018 21:10:53 PlexConnect: Python: 2.7.14 (default, Dec 14 2017, 15:51:29)
[GCC 6.4.0]
Feb 02,2018 21:10:53 PlexConnect: Host OS: linux2
Feb 02,2018 21:10:53 PlexConnect: PILBackgrounds: Is PIL installed? True
Feb 02,2018 21:10:53 PlexConnect: IP_self: 192.168.1.11
Feb 02,2018 21:10:53 DNSServer: Started
Feb 02,2018 21:10:53 DNSServer: ***
Feb 02,2018 21:10:53 DNSServer: DNSServer: Serving DNS on 192.168.1.11 port 53.
Feb 02,2018 21:10:53 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.1.11
Feb 02,2018 21:10:53 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
Feb 02,2018 21:10:53 DNSServer: forward other to higher level DNS: 8.8.8.8
Feb 02,2018 21:12:14 DNSServer: DNS request received!
Feb 02,2018 21:12:14 DNSServer: Source: (‘192.168.1.209’, 49273)
Feb 02,2018 21:12:14 DNSServer: Domain: p29-buy.itunes-apple.com.akadns.net
Feb 02,2018 21:12:14 DNSServer: ***forward request
Thanks!
Please disregard. I added the cert according to the instructions below and it worked:
Select ‘General’ and select ‘Network’
set the DNS server to 192.168.1.149
Select ‘General’ highlight ‘Send Data To Apple’, and briefly press ‘Play’ on the remote.
Select 'Add Profile"
Enter http://trailers.apple.com/trailers.cer to install certificates
:wink: , glad it works.
I updated the instructions to include both steps, i just assumed the old documentation linked to both… My mistake.
