PlexConnect installation corrupt and not starting
I had to re-partition my OS drive and restore from an image. OpenPlex/Plex Connect is not starting and says that the theme is corrupt, but when I try to reinstall the theme again (or any of the other default ones), it never finishes. OpenPlex v 0.5 OsX 10.12
I have deleted it from apps, now it won’t reinstall… no errors, etc… just seems to hang… my DNS servers are set to google.
nevermind wrong forum
Reinstall app using workaround in OpenPlex topic.
Ok here is a work around until the installer app is fixed, run the following scripts via script editor:
Part1
After the Part1 script completes (I believe Part1 script will end with the result “”) run the ProgressLabel script over and over again (until the ProgressLabel script says “Cloning OpenPlex Complete”)
ProgressLabel
Last run Part3 (OpenPlex will display in the menubar when it has been successfully installed):
Part3
When we have time to fix the bug(s) they will be resolved, until then sorry for the inconvenience.
Video example:
https://www.youtube.com/watch?v=Cm2O8o1qWj4
