Plexconnect is not working! HELP!
ATV Version: 3
DNS on the ATV: 192.168.0.7
Device and OS: PC - Windows 7
Local Plexconnect IP: 192.168.0.7
Media stored: Local drive
Plex media server installed on same machine as Plexconnect.
Settings.CFG
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 8.8.8.8
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = False
ip_pms = 192.168.0.7
port_webserver = 80
Hopefully this issue is similar enough to what's happening here but I'm stuck here. Obviously nothing on the ATV3 had changed. I had an error message before so I changed the "enable_dnsserver" to false and it took care of it but I'm still stuck.
Here's my log file:
08:33:49 PlexConnect: started: 08:33:49
08:33:49 PlexConnect: ***
08:33:49 PlexConnect: PlexConnect
08:33:49 PlexConnect: Press ENTER to shut down.
08:33:49 PlexConnect: IP_self: 192.168.0.7
08:33:49 PlexGDM: ***
08:33:49 PlexGDM: looking up Plex Media Server
08:33:50 PlexGDM: servers discovered: 1
08:33:50 PlexConnect: PMS: 192.168.0.7:32400
08:33:50 WebServer: started: 08:33:50
08:33:50 WebServer: ***
08:33:50 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
Any help would be greatly appreciated.
If you have the DNS server set to false then it is not going to work, unless you have setup your own DNS server and IP redirection (this is why it says on the wiki to not mess with those setting unless you know what you are doing).
I changed it back to True and here's the log. Any idea?
12:28:16 PlexConnect: started: 12:28:16
12:28:16 PlexConnect: ***
12:28:16 PlexConnect: PlexConnect
12:28:16 PlexConnect: Press ENTER to shut down.
12:28:16 PlexConnect: IP_self: 192.168.0.7
12:28:16 PlexGDM: ***
12:28:16 PlexGDM: looking up Plex Media Server
12:28:17 PlexGDM: servers discovered: 1
12:28:17 PlexConnect: PMS: 192.168.0.7:32400
12:28:17 DNSServer: started: 12:28:17
12:28:17 DNSServer: Failed to create socket on UDP port 53: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted
12:28:17 WebServer: started: 12:28:17
12:28:17 WebServer: ***
12:28:17 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
Try rebooting your PC and ATV.
If it gives the same port 53 error then you do have another DNS server running, use the following to find out what it is:
http://technet.microsoft.com/en-gb/sysinternals/bb897437.aspx
Hello,
For me it's KO, help me please !!!  :S  :S  :S
Where is my problem?
**QNAP**
Version 569L with firmware 4.0.1
Web Server port : running on port 80
IP adresse QNAP : 192.168.0.250
Plex Server version : 0.9.7.28 (running on port 32400)
**APTV**
Software APTV: 5.3 (6105)
Version system : 6.1.4 (10B809)
IP adresse: 192.168.0.16
DNS : 192.168.0.250
**Python Version**
2.7
**Install Location PlexConnect**
/share/MD0_DATA/.qpkg
**Source Install**
**Setting.cfg**
[PlexConnect]
port_pms = 32400
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.0.250
port_webserver = 80
**<n /share/MD0_DATA/.qpkg/PlexConnect/PlexConnect.py -d &**
[1] 21228
[~] # 00:40:10 PlexConnect: ***
00:40:10 PlexConnect: PlexConnect
00:40:10 PlexConnect: Press CTRL-C to shut down.
00:40:10 PlexConnect: started: 00:40:10
00:40:10 PlexConnect: IP_self: 192.168.0.250
00:40:10 DNSServer: started: 00:40:10
00:40:10 DNSServer: ***
00:40:10 DNSServer: Starting up.
00:40:10 DNSServer: intercept trailers.apple.com: 192.168.0.250
00:40:10 DNSServer: forward other to higher level DNS: 8.8.8.8
00:40:11 WebServer: started: 00:40:11
00:40:11 WebServer: ***
00:40:11 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
00:40:11 PlexGDM: ***
00:40:11 PlexGDM: looking up Plex Media Server
00:40:12 PlexGDM: servers discovered: 2
00:40:12 XMLConverter: PlexGDM - PMS: 192.168.0.250:32400
00:40:18 DNSServer: DNS request received!
00:40:18 DNSServer: Source: ('192.168.0.16', 56836)
00:40:18 DNSServer: Domain: phobos.apple.com
00:40:18 DNSServer: ***forward request
00:40:18 DNSServer: -> DNS response from higher level
00:40:19 DNSServer: DNS request received!
00:40:19 DNSServer: Source: ('192.168.0.16', 56836)
00:40:19 DNSServer: Domain: phobos.apple.com
00:40:19 DNSServer: ***forward request
00:40:19 DNSServer: -> DNS response from higher level
00:40:22 DNSServer: DNS request received!
00:40:22 DNSServer: Source: ('192.168.0.16', 56836)
00:40:22 DNSServer: Domain: phobos.apple.com
00:40:22 DNSServer: ***forward request
00:40:22 DNSServer: -> DNS response from higher level
00:40:31 DNSServer: DNS request received!
00:40:31 DNSServer: Source: ('192.168.0.16', 56836)
00:40:31 DNSServer: Domain: phobos.apple.com
00:40:31 DNSServer: ***forward request
00:40:36 DNSServer: DNS request received!
00:40:36 DNSServer: Source: ('192.168.0.16', 59856)
00:40:36 DNSServer: Domain: 44-courier.push.apple.com
00:40:36 DNSServer: ***forward request
00:40:36 DNSServer: -> DNS response from higher level
00:40:44 DNSServer: DNS request received!
00:40:44 DNSServer: Source: ('192.168.0.16', 59856)
00:40:44 DNSServer: Domain: 44-courier.push.apple.com
00:40:44 DNSServer: ***forward request
00:40:44 DNSServer: -> DNS response from higher level
00:40:58 DNSServer: DNS request received!
00:40:58 DNSServer: Source: ('192.168.0.16', 56836)
00:40:58 DNSServer: Domain: phobos.apple.com
00:40:58 DNSServer: ***forward request
00:40:58 DNSServer: -> DNS response from higher level
**French error message on APTV3**
"Bandes-annonces non disponible. Réessayez plus tard."
/Fab.
I try with port 82 Server web on my QNAP and ip_dnsmaster=192.168.0.1 in Setting.cfg but doesn't work !  :wacko:
Show my log:
[/share/MD0_DATA/.qpkg/PlexConnect] # vi PlexConnect.log
11:31:52 PlexConnect: started: 11:31:52
11:31:52 PlexConnect: IP_self: 192.168.0.250
11:31:52 Settings: getsetting enable_dnsserver=True
11:31:52 DNSServer: started: 11:31:52
11:31:52 Settings: getsetting ip_dnsmaster=192.168.0.1
11:31:52 DNSServer: ***
11:31:52 DNSServer: Starting up.
11:31:52 DNSServer: intercept trailers.apple.com: 192.168.0.250
11:31:52 DNSServer: forward other to higher level DNS: 192.168.0.1
11:31:52 WebServer: started: 11:31:52
11:31:52 Settings: getsetting ip_webserver=192.168.0.250
11:31:52 Settings: getsetting port_webserver=80
11:31:52 WebServer: ***
11:31:52 WebServer: WebServer: Serving HTTP on 192.168.0.250 port 80.
11:31:52 ATVSettings: init class CATVSettings
11:31:52 ATVSettings: load settings
11:31:52 Settings: getsetting enable_plexgdm=True
11:31:52 PlexGDM: ***
11:31:52 PlexGDM: looking up Plex Media Server
11:31:52 PlexGDM: Sending discovery message: M-SEARCH * HTTP/1.0
11:31:52 PlexGDM: Received data from ('192.168.0.250', 32414)
11:31:52 PlexGDM: Data received:
 HTTP/1.0 200 OK^M
Content-Type: plex/media-server^M
Resource-Identifier: 79f0ecb9370fe2038efc04ec732be4653ddcce40^M
Port: 32400^M
Updated-At: 1374982144^M
Version: 0.9.7.28.0-2b33a71^M
^M
11:31:53 PlexGDM: servers discovered: 1
11:31:53 PlexGDM: Serveur Plex 192.168.0.250:32400
11:31:53 XMLConverter: PlexGDM - PMS: 192.168.0.250:32400
11:31:59 DNSServer: DNS request received!
11:31:59 DNSServer: Source: ('192.168.0.16', 62087)
11:31:59 DNSServer: Domain: phobos.apple.com
11:31:59 DNSServer: ***forward request
11:32:04 DNSServer: DNS request received!
 HTTP/1.0 200 OK^M
Port: 32400^M
^M
11:32:04 DNSServer: Source: ('192.168.0.1', 35322)
11:32:04 DNSServer: Domain: phobos.apple.com
11:32:04 DNSServer: ***forward request
11:32:09 DNSServer: DNS request received!
11:32:09 DNSServer: Source: ('192.168.0.16', 54268)
11:32:09 DNSServer: Domain: trailers.apple.com
11:32:09 DNSServer: ***intercept request
11:32:09 DNSServer: -> DNS response: 192.168.0.250
11:32:09 DNSServer: Source: ('192.168.0.1', 35322)
11:32:09 DNSServer: Domain: phobos.apple.com
11:32:09 DNSServer: ***forward request
11:32:14 DNSServer: DNS request received!
11:32:14 DNSServer: Source: ('192.168.0.16', 54268)
11:32:14 DNSServer: Domain: trailers.apple.com
11:32:14 DNSServer: ***intercept request
11:32:14 DNSServer: -> DNS response: 192.168.0.250
11:32:14 DNSServer: Source: ('192.168.0.1', 35322)
11:32:14 DNSServer: Domain: phobos.apple.com
11:32:14 DNSServer: ***forward request
11:32:19 DNSServer: DNS request received!
11:32:19 DNSServer: Source: ('192.168.0.1', 35322)
11:32:19 DNSServer: Domain: phobos.apple.com
11:32:19 DNSServer: ***forward request
11:32:24 DNSServer: DNS request received!
11:32:24 DNSServer: Source: ('192.168.0.16', 54268)
11:32:24 DNSServer: Domain: trailers.apple.com
11:32:24 DNSServer: ***intercept request
11:32:24 DNSServer: -> DNS response: 192.168.0.250
11:32:24 DNSServer: Source: ('192.168.0.1', 35322)
11:32:24 DNSServer: Domain: phobos.apple.com
11:32:24 DNSServer: ***forward request
11:32:29 DNSServer: DNS request received!
11:32:29 DNSServer: Source: ('192.168.0.1', 35322)
11:32:29 DNSServer: Domain: phobos.apple.com
11:32:29 DNSServer: ***forward request
11:32:34 DNSServer: DNS request received!
11:32:34 DNSServer: Source: ('192.168.0.16', 62087)
11:32:34 DNSServer: Domain: phobos.apple.com
11:32:34 DNSServer: ***forward request
11:32:39 DNSServer: DNS request received!
11:32:39 DNSServer: Source: ('192.168.0.1', 35322)
11:32:39 DNSServer: Domain: phobos.apple.com
11:32:39 DNSServer: ***forward request
11:32:44 DNSServer: DNS request received!
11:32:44 DNSServer: Source: ('192.168.0.1', 35322)
11:32:44 DNSServer: Domain: phobos.apple.com
11:32:44 DNSServer: ***forward request
11:32:49 DNSServer: DNS request received!
11:32:49 DNSServer: Source: ('192.168.0.1', 35322)
11:32:49 DNSServer: Domain: phobos.apple.com
11:32:49 DNSServer: ***forward request
11:32:54 DNSServer: DNS request received!
11:32:54 DNSServer: Source: ('192.168.0.16', 54268)
11:32:55 DNSServer: Domain: trailers.apple.com
11:32:55 DNSServer: ***intercept request
11:32:55 DNSServer: -> DNS response: 192.168.0.250
11:32:55 DNSServer: DNS request received!
11:32:55 DNSServer: Source: ('192.168.0.1', 35322)
11:32:55 DNSServer: Domain: phobos.apple.com
11:32:55 DNSServer: ***forward request
11:33:00 DNSServer: DNS request received!
11:33:00 DNSServer: Source: ('192.168.0.1', 35322)
11:33:00 DNSServer: Domain: phobos.apple.com
11:33:00 DNSServer: ***forward request
11:33:05 DNSServer: DNS request received!
11:33:05 DNSServer: Source: ('192.168.0.1', 35322)
11:33:05 DNSServer: Domain: phobos.apple.com
11:33:05 DNSServer: ***forward request
11:33:06 PlexConnect: Shutting down.
11:33:07 WebServer: Shutting down.
11:33:07 ATVSettings: save settings
11:33:10 DNSServer: Shutting down.
11:33:10 PlexConnect: shutdown
floyd:
aTV asks specifically for port 80. All of you logs show, that PlexConnect/WebServer is NEVER getting any request.
You can't just change it to your liking. If port 80 is already used on your server you either have to free it, or install a port forwarding to the port configured in PlexConnect.
floyd:
Thank you Baa for your help !  :)
This is my QNAP Web Server configuration:
![post-156548-0-46875900-1375007810.png|690x272](upload://rJYrd1tEKJGTBBMklyeAybNIYbE.png)
![post-156548-0-95666600-1375007816.png|690x252](upload://rXIEjxYk8cyg3vRusOc3GiT3d7y.png)
It's OK?
This is my Setting.cfg configuration:
[PlexConnect]
port_pms = 32400
ip_dnsmaster = 192.168.0.1 (Default Gateway to my home router, it's OK?)
ip_webserver = 192.168.0.250 (My QNAP adresse and Plex installation, it's OK?)
loglevel = High
logpath = .
ip_pms = 192.168.0.250  (My QNAP adresse, Plex installation, it's OK?)
port_webserver = 80 (it's OK?)
Floyd, the web server port still shows 80 on Plexconnect, 82 on Qnap
I guess you have to add a second IP to your device and make the qnap listen to the old and original IP and let plexconnect use the new one, this should work, so both could use port 80.
What is the problem? It's correct, it is not?
OK, but what is the process? I have firmware 4.0.1, it's not possible via web interface
no, I don't have any clue what OS is used by qnap, if its linux based its pretty simple by just adding another interface using ifconfig
You are probably better off asking this in the QNAP specific thread.
