Thank you for this very nice program and all your hard efforts making this working on my good old iMac.
Sent from my iPad using Tapatalk HD
Hey love this anyway to add the password to the app?
It would be nice if the app loaded without asking for this, it would also make it easier to launch on startup
Thanks for taking the time to build this.
Any actual devs want to take a crack at this? Thats out of my knowledge unfortunately. :|
Dan
Did anyone come up for a solution for the password on startup?
thanx.
This is great. Thanks for spending the time in doing this. :D
Updated as of 2013-07-20. :)
Where can I get the latest update, pls?
Thanks and great work, mate...
Kris
You can always get the latest version from the first post. The date is updated when there is an update. Thanks!
Sent from my Nexus 7 using Tapatalk 2
You can always get the latest version from the first post. The date is updated when there is an update. Thanks! Sent from my Nexus 7 using Tapatalk 2
Thank you... :) ...love it
Pertfect! Do I need to put the application in Login Items?
If you want it to start at login you do.
But is it also possible not to show the icon in the dock?
Dock Dodger. I use this app for a few things. There is a way to edit an app's plist file to disable it showing in the dock, this app just does it for you with one click instead of you going in and changing the .plist manually.
That is it then...end of the Plexconnect DMG option? Damn Apple!! :)
NO.
YOU CAN MAKE MUCH BTTER BUGLESS APP WITH AWESOME APPLESCRIPT IN POST #97 HERE:
IF HELP NEEDED tell me.
NO.
Thanks ..sent you a message ...I do need help.
Hi guys, i'm getting my ATV this sunday and was looking for this. I also found this thing on the web: http://plexconnect.org/mac/
Is this the same or is this a scam?
Greetz,
XyonN
Netherlands
It is a scam.
Thank you!
Answered ..
Greetz,
XyonN
Netherlands
down
It is a scam.
+1
I have a strange issue when using Plex Connect (and Plexify). Episodes are periodically being shown as "unwatched" even when they have been watched. Not with all shows though. And periodically when pressing play on the Apple Remote (the silver centre button on the remote) I get three choices on screen "Mark as watched", "Mark as unwatched" and "Change poster/picture?". Then I have to exit using the Menu button and use the Play/Pause button to watch. Can anyone explain?
why??? it worked like a charm!!! I am away from a computer on which it was downloaded and wanted to download it again :(
This is not the Plexify thread - it was the thread for the Platypus wrapper which is now dead.
