PlexConnect Mac App
I read it...I also read it before I posted my comments.
Not sure what you are getting at.
Are you saying you are an experienced dev or have spoken to one about this? You post doesn't elude to either.
I am one of the three people behind PlexConnect and was pointing out the reasons why we do not have it as a standard Mac applications at the moment (although remember it runs on more than OSX).
 I have Plex media serving running on my Mac, I downloaded PlexConnect but how do you start it?
Read the install guide in the wiki (link is in the sticky).
@Dan
Could you change the App with the latest build. Thx very much.
@Dan
Posted! Sorry it took so long. I moved over the weekend and Cox screwed up my service hopefully it'll get fixed by today.
Thx  so much !
Maybe you could write a little "How to" so we could do it ourselves.
Thx  so much !
I will maybe write one. theres a short one works perefect in here:
http://forums.plexapp.com/index.php/topic/70149-has-anyone-created-an-applescriptapplication-to-launch-plexconnect-at-startup/
post 7
Could I ask you to version your builds somehow. Otherwise I'm very pleased you've kept pace with the iBaa builds but I get confused as to which new update to go for!
Great work BTW!
Great work BTW!
i suggest you to follow the guide in post 7 here:
after understanding it it's really easy. and whenever there's an update you just switch the folder content to the new files .. and he made the script very smart-if it can't find atv or pms it'll just keep looking till finding it.
and make it seamless with dock dodger ..
Great work BTW!
If you go to About PlexConnect in the menubar, the date of the build is in place of a version number.
This works flawlessly for me - Than you so much!  :D
Got it, sorry!
Anybody else experience this when running the PlexConnect app?
http://forums.plexapp.com/index.php/topic/73251-plexconnect-works-for-limited-time-then-hangs/#entry423083
I threw together these .App packages to make things a little easier for myself. They just a wrapped version of the various scripts that can be found here. No special sauce or anything like that. Also, I'm not a developer so unfortunately I won't be able to help if you run into trouble.
Just drag it anywhere on your system with Plex Media Server running and then start the app.
You still need to point the DNS IP on the AppleTV to your computer that is running Plex.
I hope this helps for some people who for whatever reason aren't familiar or comfortable with Terminal.
Download Latest Build:
PlexConnect App (Latest Build)
2013-07-01
(For 5.1+ Devices)
Download v0.1 Build:
PlexConnect App v0.1
2013-06-27
(For 5.01/5.02 Devices)
I hope they work out for you! Thanks!
Dan
Thanks Dan...this helps heaps for a novice like me...I am techy enough but dont know enough to write code..so this is fantastic...works well with my ATV3...disconnects sometimes, but hey, I just reconnect...so all is good.
Hello, I first would like to say that I loved the app is very useful and elegant. My doubt is whether it is possible, do update the app to the latest build of PlexConnect, directly in the application without having to wait for the application developer to do this. If possible, how do you do this update? thank you
I believe that because the app developer has to actually configure the app each update, there is no way for the app to automatically update directly from Baa's github updates.
Thanks for the reply
Updated as of 2013-07-20. :)
Thanks! I appreciate your work  :rolleyes:
Any chance this app will Work with the added use of the server setup needs?  I have a Mac Mini hosting the PMS stuff at my house and i know there were some extra steps involved in the setup.
Great work btw, Thank You.
Thank you for this!
