PlexConnect: MyPlex- No Library Sections available
Question on MyPlex in PlexConnect: The MyPlex section in PlexConnect have "No Library Sections available" PlexConnect Libraryis working great. I am signed in to MyPlex in settings and PMS published. Why is the MyPlex section not showing up? Is this how it is supposed to work? When I toggle the GDM on and off in PMS, I can get MyPlex to work but then not Library. Thanks for the excellent work!
  • ATV 3, Model MD199C/A, 6.0.1(664680.1)
  • The DNS server set on the ATV : 10.0.1.3
  • PlexConnect is installed on:Mac Mini OSX 10.9.1 (13B42)
  • PlexConnect is installed on: 10.0.1.3
  • Plex media server (PMS) is installed on:Mac Mini OSX 10.9.1 (13B42)
  • The Plex media server (PMS): Version 0.9.8.17.282-c844f09
  • Plex media server (PMS) is installed on: 10.0.1.3
  • The PlexConnect version number. GitHub: December 8, 2013, updated today.
  • Content of 'Settings.cfg' file
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
  • detailed description of the issue: PLexConnect Library and Channels sections work great. The MyPlex Section only has "No Plex Library Sections available. I am signed in to MyPlex on settings and PMS is published. When I disable GDM on PMS and restart everything, MyPlex in PlexConnect work but not the Library and Channels sections. If I enable GDM again, I get channels but not MyPlex.
  • PlexConnect Log attached
All sections are only displayed once - if your server is found local it will be in "Library". If not it will show up under MyPlex (remote/shared) servers.
Thanks much!
You can also see stuff under MyPkex as well as library, if someone shares their library with you :wink:
