PlexConnect on QNAP w/ ATV3
Problem: DNS intercept not working for "trailers".
4:28:36 DNSServer: DNS request received!
14:28:36 DNSServer: Source: ('192.168.1.19', 53180)
14:28:36 DNSServer: Domain: a2.mzstatic.com
14:28:36 DNSServer: ***forward request
14:28:36 DNSServer: -> DNS response from higher level
However no response from PMS for "trailers.apple.com"
14:28:50 DNSServer: DNS request received!
14:28:50 DNSServer: Source: ('192.168.1.19', 56118)
14:28:50 DNSServer: Domain: trailers.apple.com
14:28:50 DNSServer: ***intercept request
14:28:50 DNSServer: -> DNS response: 192.168.1.4
log showing services started:
14:25:20 PlexConnect: started: 14:25:20
14:25:20 PlexConnect: ***
14:25:20 PlexConnect: PlexConnect
14:25:20 PlexConnect: Press CTRL-C to shut down.
14:25:20 PlexConnect: IP_self: 192.168.1.4
14:25:20 DNSServer: started: 14:25:20
14:25:20 DNSServer: ***
14:25:20 DNSServer: Starting up.
14:25:20 DNSServer: intercept trailers.apple.com: 192.168.1.4
14:25:20 DNSServer: forward other to higher level DNS: 192.168.1.1
14:25:21 WebServer: started: 14:25:21
14:25:21 WebServer: ***
14:25:21 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 9092.
14:25:21 PlexGDM: ***
14:25:21 PlexGDM: looking up Plex Media Server
14:25:22 PlexGDM: servers discovered: 1
14:25:22 XMLConverter: PlexGDM - PMS: 192.168.1.4:32400
IP addresses explained:
QNAP=192.168.1.4 (PMS v0.9.7.12.4 & PlexConnect latest git from https://github.com/iBaa/PlexConnect)
DNS Server=192.168.1.1 (router)
ATV3=192.168.1.19 (DNS set as 192.168.1.1)
Settings.cfg
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 192.168.1.1
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
port_webserver = 9092
ip_pms = 192.168.1.4
Q1: any idea how I can troubleshoot this?
Q2: should I be majking any changes to "assets" to advertise the content from PMS?
Thanks.
After some mucking around maanged to get working.
1. original problem could be webserver not enabled in QNAP (Network Services), however PlexConnect log didn't indicate any issues with web-server.
2. delete Settings.cfg and let Settings.py create one (see below)
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_dnsmaster = 8.8.8.8
loglevel = Normal
ip_pms = 192.168.178.10
3. left DNS as 8.8.8.8, haven't tried changing to my DNS. "RULE #1, don't try fix what ain't broken."
4. PMS IP address is wrong, however I believe enable_plexgdm = True overides this. "RULE #2, always follow RULE #1."
cheerio fellows, happy days!
Yeah the fallback IP address for the PMS in settings should not need to be changed for most users.
It also helps us troubleshoot GDM issues.
