PLexconnect on rPI 2 possible?
I would like to install plexconnect on a rPI 2 to Work together with my Apple TV 3. Does someone know if this is possible?
Yes, install a basic raspbian config, I used one without a gui, then install python and pll, you can add it to startup on boot, or with a command, it works fairly okay
Is plexconnect part of raspbian? What is plll?
pill/pillow is an image processing library for python, used for the backgrounds/fanart.
so there is no plexconnect? what do I do with python and pll?
Huh?
PlexConnect is - afaik - not part the raspbian linux distribution. However, it is available on github. So just download, unzip and use it.
