PlexConnect - still nothing - Trailers unavailable
Hi All,
I’ve gone through all the installation steps multiple time in various different ways and when I click trailers I am still getting “Trailers is unavailable. Try again later.”
Any one have any idea what’s going on from the below settings and log? It doesn't seem to be looking for the PMS...
Thanks v much
F
ATV 2 - 6.0.2 (6646.81.1)
DNS server on ATV: 192.168.0.24
PlexConnect running on macbook pro OS 10.9 mavericks
PMS running on the same machine
PMS version 0.9.8.18.290-11b7fdd
Local IP address is: 192.168.0.24
PlexConnection version 0.3.1+ downloaded 16 feb at around 19.00 London time
Settings.cfg  as below:
And my log file is here: http://pastebin.com/fEZ1trcx
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
ATV doesn't seem to accept the application.js file. What about the certs?
Installed just fine with the iphone utility .. did the process a few times and still nothing:
Is it weird i dont see the following in the console as the installation suggests?
PlexGDM ***
PlexGDM: looking up Plex Media Server
PlexGDM: ***
PS: i checked on the apple tv and the cert/profile is there..
I don't know, were did you find that? Maybe the doc is old?
GDM is done per aTV now, actually one of the first steps after application.js is "running". So it should be somewhere at the end of your posted log - no more at the beginning as it was earlier.
Used this instructions as well as others https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Mac
edit: Also used these after https://langui.sh/2013/08/27/appletv-ssl-plexconnect/
Try to install your certificate using these steps instead:
https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Certificate-via-Ethernet
