Plexconnect suddenly stopped working.
So i got home from work and thought i would watch a movie and now i get "an error occurred loading this content".
Now i have searched on the forum for hours and tried everything but i cant found out what is wrong.
So i hope you guys can help out!
Here is the log:
17:44:29 PlexConnect: started: 17:44:29
17:44:29 PlexConnect: IP_self: 192.168.1.82
17:44:29 DNSServer: started: 17:44:29
17:44:29 DNSServer: ***
17:44:29 DNSServer: DNSServer: Serving DNS on 192.168.1.82 port 53.
17:44:29 WebServer: started: 17:44:29
17:44:29 WebServer: ***
17:44:29 WebServer: WebServer: Serving HTTP on 192.168.1.82 port 80.
17:44:29 PlexAPI: ***
17:44:29 PlexAPI: looking up Plex Media Server
17:44:29 WebServer: WebServer: Serving HTTPS on 192.168.1.82 port 443.
17:44:30 PlexAPI: servers discovered: 1
17:44:30 XMLConverter: PlexGDM - PMS: 192.168.1.82:32400
17:44:57 PlexConnect: Shutting down.
17:44:57 WebServer: Shutting down.
17:44:58 WebServer: Shutting down.
17:45:02 DNSServer: Shutting down.
17:45:02 PlexConnect: shutdown
All apps works but when i play any file in the trailer.app i get the erro.
Can you see anything wrong in the log?
Try turning on verbose logging. In the configuration, set log level to High. Then repost the log.
Hope i did it right: http://pastebin.com/ncpYZ
cant figure out why this stopped working.
Don't see any obvious errors. When you tried to play Monsters University, did it actually play or did you get an error?
I did get an error directly when i pressed play! Im wondering if it can be any trailer cert error.
Doesn't look like a cert error. Did you try restarting PMS, PlexConnect and the AppleTV. You can also try forcing transcoding in the settings to see if its an error with the file format.
Okey, if i start the Plex Connect without PMS i get this : 18:44:46 DNSServer: DNS request received!
18:44:46 DNSServer: Source: ('192.168.1.90', 62362)
18:44:46 DNSServer: Domain: init-p01st.push.apple.com
18:44:46 DNSServer: ***forward request
18:44:46 DNSServer: -> DNS response from higher level
18:44:46 DNSServer: Source: ('192.168.1.90', 60235)
18:44:46 DNSServer: Domain: 30-courier.push.apple.com
18:44:47 DNSServer: DNS request received!
18:44:47 DNSServer: Source: ('192.168.1.90', 64725)
18:44:47 DNSServer: Domain: init.itunes.apple.com
18:44:47 DNSServer: ***forward request
18:44:47 DNSServer: -> DNS response from higher level
18:44:48 DNSServer: DNS request received!
18:44:48 DNSServer: Source: ('192.168.1.90', 55392)
18:44:48 DNSServer: Domain: EVSecure-ocsp.verisign.com
18:44:48 DNSServer: ***forward request
18:44:48 DNSServer: -> DNS response from higher level
18:44:48 DNSServer: Source: ('192.168.1.90', 61641)
18:44:48 DNSServer: Domain: EVIntl-ocsp.verisign.com
18:44:48 DNSServer: Source: ('192.168.1.90', 60491)
18:44:48 DNSServer: Domain: configuration.apple.com
18:44:48 DNSServer: Source: ('192.168.1.90', 57488)
18:44:48 DNSServer: Domain: xp.apple.com
18:44:48 DNSServer: Source: ('192.168.1.90', 53700)
18:44:48 DNSServer: Domain: itunes.apple.com
18:44:51 DNSServer: DNS request received!
18:44:51 DNSServer: Source: ('192.168.1.90', 56725)
18:44:51 DNSServer: Domain: se.itunes.apple.com
18:44:51 DNSServer: ***forward request
18:44:51 DNSServer: -> DNS response from higher level
18:44:51 DNSServer: Source: ('192.168.1.90', 61937)
18:44:51 DNSServer: Domain: a4.mzstatic.com
18:44:51 DNSServer: Source: ('192.168.1.90', 52346)
18:44:51 DNSServer: Domain: a2.mzstatic.com
18:44:52 DNSServer: DNS request received!
18:44:52 DNSServer: Source: ('192.168.1.90', 52573)
18:44:52 DNSServer: Domain: a1.mzstatic.com
18:44:52 DNSServer: ***forward request
18:44:52 DNSServer: -> DNS response from higher level
18:44:52 DNSServer: Source: ('192.168.1.90', 57783)
18:44:52 DNSServer: Domain: a5.mzstatic.com
18:44:52 DNSServer: Source: ('192.168.1.90', 64774)
18:44:52 DNSServer: Domain: a3.mzstatic.com
Log looks good to me...
Is the file available? Stored on a external/unmounted USB drive? PMS option "require authentication"?
What happens when you enter the final address in your browser? In browser on a different computer?
-> http://192.168.1.82:32400/library/parts/34/file.mp4
Thanks everyone, i checked the Plex Web again and all my files were "Not Available" so i removed all paths to the files and added them again and now it works:)
Where do i donate?
>>Where do i donate?
see Signature. or "pinned" thread.
Where do i donate?
once in a blue moon PMS doesn't quantify the mediafile I've shown it, and I find if hit that analyze button on PMS 99.9% of the time it works.
