PlexConnect-Support for .ts-files + Bluray folder
are there any news about supporting .ts-files or BR-Folder?
Thanks +
BR
Peter
Thanks +
BR
Peter
Please take a look at the wiki for how to turn the log level to high (the one you provided is just the standard one it think).
Also could you upload a sample somewhere so that we can have a play with?
Hi f00b4r,
i read the wiki and set the log-level to "high";-)
Thanks + BR
Peter
Hmm okay not much information in there then.
NB it needs to be "High" (with a capital)
Do you have a sample?
Hi f00b4r,
ok, i made a sample for you:
https://dl.dropboxusercontent.com/u/7773185/Testfile_PlexConnect_Paranorman.ts
Hope it helps to figure out:-)
BR + Many thanks for all your work,
Peter
any news about the .ts-sample for Playbeck within PlexConnect?
Thanks & BR
Peter
Unfortunately I have been tied up this week and am now out of the country for a week.
I will take a look on my return if it is still outstanding.
Hi f00b4r,
thanks for reply! Great to hear/ read you soon... :) Have a nice week!
BR
Peter
Hi f00b4r,
any news about support for .ts-files and so on...?
Thanks + BR
Peter
Just put my ATV back in office where it is easy to run tests with.
I get the same issue, it plays fine in iOS but not in PlexConnect, but i am not sure why.
We are looking at it though so hopefully have an answer soon.
Good and bad news, but hopefully it means it will get fixed sooner rather than later.
Some further testing shows it appears to be a PMS issue. It will play on PlexConnect if you set 720p 4meg or below, above that and you only get audio, even if selecting force transcoding. When i realised this i went back to my iPhone and realised that i had local wifi set to 3meg - if i set it to 8 meg i got the same issue.
So i think it needs to be reported in the PMS server forum, link to this post though and you already have a sample file for which they can test with:
Many thanks for answering!
Not sure, if this is a PMS issue, because 1080p transcoding is working for my Samsung TV f8090, but it plays directly too. I only tested your transcoding config. It also works very well with 1080p and 20mbit transcoding on my Roku 3.
So is it really no PlexConnect issue…?
Thanks for all your work!
BR
Peter
Well possibly it might be better to say a PMS issue as relates to the stream it provides iOS devices at higher bitrates.
Maybe it tries to direct play it at the higher bit rates and so causes the issue but the Plex team will probably have a better idea of what is going on.
Did you get any answers on this in the PMS forum?
http://forums.plexapp.com/index.php/topic/62832-plex-media-server/?p=437389
Looks as if some changes were made in the new PMS, does it make a difference?
Hey there,
i recently installed the PMS (0.9.8.4) and get the same issue. Direct playback of ts-files just gives sound and no picture on my ATV3.
I wanted to use a small WHS2011-system as mediaserver, but if i have to force transcoding it's cpu isn't strong enough (2x1.5GHz AMD Turion).
So now i have the following setup working:
- Files on the WHS
- PMS and PlexConnect on my laptop getting the files by LAN from the server
- ATV3 as client asking the laptop to transcode the files for playback to 720p/4Mb  :blink:
This is GREAT compared to the old itunes-solution!
But is there a solution for playing 1080i-ts-files directly on the ATV3 without transcoding on the PMS-system?
cy@n
cyan... what is the codec used in your .ts files? If it's NOT h264, I guess aTV won't be able to handle it without transcoding...
I think we need some more detailed media info to discuss this.
PMS says:
MEDIEN
  • Video Auflösung 720p
  • Dauer 11:32:13
  • Bitrate 10429 kbps
  • Width 1280
  • Height 720
  • Seitenverhältnis 1.78
  • Container MPEGTS
DATEI
  • Accessible No
  • Exists No
  • Dauer 11:32:13
  • Datei M: v\filename.ts
  • Size 5.84 GB
  • Container MPEGTS
  • Packet Length 188
VIDEO
  • Codec H264
  • Bitrate 9000 kbps
  • Bit Depth 8
  • CABAC 1
  • Chroma Subsampling 4:2:0
  • Color Space yuv
  • Dauer 1:20:12
  • Bildrate 50,000 fps
  • Has Scaling Matrix 0
  • Height 720
  • Ebene 4.0
  • Profil main
  • Ref Frames 2
  • Scan Type progressive
  • Width 1280
AUDIO
  • Codec MP2
  • Kanäle Stereo
  • Bitrate 192 kbps
  • Sprache Deutsch
  • Bitratenmodus CBR
  • Dauer 1:20:12
  • Abtastfrequenz 48000 Hz
AUDIO
  • Codec MP2
  • Kanäle Stereo
  • Bitrate 192 kbps
  • Sprache English
  • Bitratenmodus CBR
  • Dauer 1:20:12
AUDIO
  • Codec AC3
  • Kanäle 5.1
  • Bitrate 448 kbps
  • Sprache Deutsch
  • Bit Depth 16
  • Bitratenmodus CBR
  • Dialog Norm -27 dB
  • Dauer 1:20:12
UNTERTITEL
  • Sprache Deutsch
Hi any news? I get ts files only working on ATV3 and PMS if i force transcoding.
Media details please.
