Hi All,
I am having an issue when trying to run plex connect from my 2007 Macbook. This machine is currently hosting my PMS also. My Apple TV is running 5.02 firmware and has a profile configured with my SSL cert. I have no problem cutting the certificate again and running plexconnect from my macbook air so I believe I am configuring everything and creating the certificates correctly. When I try to run plex connect from my macbook (2007) and select trailers I see the application.js however trailers will spin for ~30 seconds then show trailers unavailable. I originally thought this to be a permissions issue as I could not overwrite config files however I have since corrected this and given my account read/write access to all items within plexconnect-master. The issue remains, any thoughts on what I can check?
Atv 2 (5.3)
Macbook (2007 model) 10.6.8
PMS 0.9.8.6.175
Plex Connect IP = 192.168.1.119 (PMS on same machine)
Contents of Settings.cfg
[PlexConnect]
enable_webserver_ssl = True
port_pms = 32400
ip_plexconnect = 0.0.0.0
certfile = /applications/plexconnect-master/assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
ip_pms = 192.168.178.10
port_webserver = 80
loglevel = Normal
logpath = .
enable_dnsserver = True
enable_plexgdm = True
port_ssl = 443
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
Contents of PlexConect.log
17:40:09 PlexConnect: IP_self: 192.168.1.119
17:40:09 DNSServer: started: 17:40:09
17:40:09 DNSServer: ***
17:40:09 DNSServer: DNSServer: Serving DNS on 192.168.1.119 port 53.
17:40:09 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.119
17:40:09 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
17:40:09 DNSServer: forward other to higher level DNS: 8.8.8.8
17:40:09 WebServer: started: 17:40:09
17:40:09 WebServer: ***
17:40:09 WebServer: WebServer: Serving HTTP on 192.168.1.119 port 80.
17:40:09 PlexGDM: ***
17:40:09 PlexGDM: looking up Plex Media Server
17:40:09 WebServer: WebServer: Serving HTTPS on 192.168.1.119 port 443.
17:40:10 PlexGDM: servers discovered: 1
17:40:10 XMLConverter: PlexGDM - PMS: 192.168.1.119:32400
17:40:20 DNSServer: DNS request received!
17:40:20 DNSServer: Source: ('192.168.1.117', 64884)
17:40:20 DNSServer: Domain: apiproxy-apiglobal-30999829.us-west-2.elb.amazonaws.com
17:40:20 DNSServer: ***forward request
17:40:20 DNSServer: -> DNS response from higher level
17:40:22 DNSServer: DNS request received!
17:40:22 DNSServer: Source: ('192.168.1.117', 63557)
17:40:22 DNSServer: Domain: e7329.g.akamaiedge.net
17:40:22 DNSServer: ***forward request
17:40:22 DNSServer: -> DNS response from higher level
17:40:24 DNSServer: DNS request received!
17:40:24 DNSServer: Source: ('192.168.1.117', 57064)
17:40:24 DNSServer: Domain: trailers.apple.com
17:40:24 DNSServer: ***intercept request
17:40:24 DNSServer: -> DNS response: 192.168.1.119
17:40:24 WebServer: serving application.js
17:41:53 PlexConnect: Shutting down.
17:41:53 WebServer: Shutting down.
17:41:54 WebServer: Shutting down.
17:41:54 DNSServer: Shutting down.
17:41:54 PlexConnect: shutdown
