PlexConnect very slow since few days
Hi Baa,
Thank you for confirming where we are at the moment.
Only use multi myplex user names to create an individual watch status and I only have a single locally based PMS.
Sometimes when using the iOS app on an ipad (locally) the shared myplex user seems to be directed to our local PMS via myplex over the internet rather than just directly which I assume it should? (Trust this explanation this make sense)?
Hope this issue can be avoided with plexconnect :slight_smile:
Great work by the way.
We will see... :-)
Have a look at the recent commit. The "slowness issue with non-owned local servers" might be solved. At least I hope so!
We will see... :-)
Yeah working good now for both users, and I believe it is also respecting individual watch status :)
Baa,
In case you hadn't picked this up - when using a local PMS with a shared myplex user name 'On Deck' is not updating after part watching a movie.
If that same myplex user watches a movie on another client and then goes back to the ATV that movie does show up under 'on deck'. Try to change the watch status though from ATV and nothing happens.
Yep, understood.
Issue is: We are hitting the shared PMS with the wrong authorisation token - with the MyPlex one, not with the server specific one.
