Since few days, using Plex from my ATV is a pain, it takes long time (almost a minute) to enter every menu and to start/navigate every media. Few days ago, it was working perfectly.
I have updated my plexConnect with latest version from git, my ATV is using gigabit wires, and running tests with Plex Home Theatre shows that the PMS (0.9.8.9) is not the origin of the issue.
Another question concerns Transcoding. Whatever option I choose, it seems always transcoding. "top" on the server shows high CPU usage by Plex New Transcoder, even when DirectPlay is enabled. Any idea why?
I noticed the same thing a couple of days ago after I updated plexconnect. I've reverted back to an older version from about three weeks ago and it works fine. Something must have been changed in the past couple weeks that has caused the load times between pages to greatly increase.
I had a very similar issue to what you are describing (loading times were over a minute) and it turned out the Plex database needed to be optimized.
To do this, go to your Plex/Web main page and at the top select More > Empty Trash, and then select More > Optimize. My loading times are now around 5 seconds or less.
Reverted back to sept 24th, still same issue very slow getting accessing trailers on every menu I select - any idea's anyone?
Same here.
Under settings in PlexConnect on ATV, there is an option "Sign out from MyPlex" or something like that, so i press there, and after that it´s work great, it´s working after i login again to.
If I am signed into the ATV with the same myplex user name that my local PMS is using then speed is fine.
Sign in under a myplex user name that I have 'shared' my library with and the 'slowness' returns?
Does this mean that shared myplex users are being forced to connect through the 'internet' rather than picking up that the PMS is in fact locally based?
Hitting a PMS with an invalid accesstoken seems to slow down the response enormously.
- We did that when PlexConnect wrongly assumed you were logged in as "*". My fault, it was an default a couple of weeks ago, might have gotten in into your ATVSettings.cfg and survived there. This is, where either signing out or deleting the faulty cfg file helped.
- Some of you seem to do it today, by signing in and trying to access another one's PMS. PlexConnect is technically not up to that task yet - it doesn't pick the right access token for the foreign server, it just "assumes" your ID/token will do the trick. With the latest modifications to the server handling, we have the foundation to fix this...
Bottomline: you are using the current version of PlexConnect somewhat out of it's specs. :-D
