Plexify | OS X Application
Tomer, leave the man alone and let him do his thing, jeeze.
This app for all users, and help it's ok
Time Machine Icon
Here :)
He wants me to create a photo, i want to know the color ..
Tasks for PlexConnect.app
Why should you change the app's icon? Just asking :)
Restyle in new version )
Ok .. :)
is it a problem if this launches plexconnect at startup, but PMS only launches at login?
I think Baa has said that Plexconnect will look for PMS when you enter Trailers.app.
yes
@nem4ara - great work so far!
@tomer1749 - you can change the running/stopped icons yourself by simply selecting "Show Package Contents" - I dropped in your black/grey icons for fun and it looks great in my system bar.
Does the "Launch PlexConnect at Startup" option start PlexConnect on boot (prior to log-in) or simply start on log-in like PMS does?
My gut says the latter since it's a menu bar item - which is perfectly fine for me, I'm 100% logged in to the computer as my daily work from home and just let the screen sleep.  It's not a headless server that needs to be screen secured on my end.
I'll add my vote to keep the icons black/grey and not add color, I like my menu bar monochromatic!
I know, it wasan't what we talked about .. I made him some icons. Never mind it's all good ;)
Test automatic create certificates and place to assets/certificates
Cool )
Are the certificates created this way specific to your computer?
certificates be created on your computer
and on other where run plexconnect app )
its be your certificates )
Good, it is important to have a private key for each person’s cert, for security reasons.
But if we want to update the folder from github we have to keep assests, don't we?
If the app can make the cert, place it somewhere in itself and edit the cfg file to point to it, it'll be perfect!
Good, it is important to have a private key for each person's cert, for security reasons.
Yes
No.
Yes
  No.
Why not?
Why not?
i think its not needed
But like this we will have to put the cert out and back in when updating plexconnect (Or till you'll add the auto-update from github which will probably do it by itself ..)
*Please add the download link to the main post so more people can download
When is version 1.1? :) :)
