.plexignore doesn't work on latest QNAP PMS
Server Version#: ver-1.20.4.3508
Player Version#: any
An example would be great.
Thank for quick reply.
So I have a folder “Power Book II” with “.plexignore” file and subfolder “Power Book II Ghost (Season 1) WEB-DL 1080p” with video files and also with “.plexignore”. Video files still persist in library.
Updating library files doesn’t help.
Screenshots and logs are attached.
2020-10-29 09_55_28-Power Book II 2020-10-29 09_55_54-Power Book II Ghost (Season 1) WEB-DL 1080p 2020-10-29 09_56_16-Plex Plex Media Server Logs_2020-10-29_09-57-02.zip (1.9 MB)
What does the contents of the .plexignore files look like?
It’s empty : )
Looks like it’s the problem.
How can Ignore all files and subfolders of the folder where “.plexignore” file exists?
If it’s in a subfolder then the following will ignore everything in that subfolder.
# Ignore all subdirectories
# Ignore all files
In your example you would only need one .plexignore file, preferably inside the folder where all the files are (so that you don’t accidentally ignore any new folders you put in there and wonder why they won’t show up).
So in that case just use do this inside the .plexignore file that live with the episode files:
# Ignore all files
You can take a look here for more info: https://support.plex.tv/articles/201381883-special-keyword-file-folder-exclusion/
Thank you very much.
The issue is solved.
