plexignore file not working
not sure if its something im doing but the plexignore file i have is not working after the most recent update.
this is the copy of my plexignore file just to be sure its not something that im doing. im running Ubuntu server 16.10 Plex Server Version 1.3.4.3285
Do you have it enabled to automatically update your libraries and do only a partial scan? If so, then it will only scan the folder where the file is. Since the .plexignore is 1 level up, it doesn’t get picked up so it won’t be triggered.
no partial scans are not selected. I have it set to update daily or I will initiate a scan from the home screen.
Ok, can you run an manual update and get me the logs.
I messaged you the log zip. I only have the one plexignore file in the !sickrage directory.
