Plexignore (still) not working
This is a followup (after 2 years) to Excluding content on Windows (latest version) as of typing this.
I still can’t get this to work. Yes i’ve rescanned the library dozens of times. I’ve analyzed the specific series folder multiple times, i’ve refreshed meta data dozens of times. the Crossovers folder is still being indexed resulting in episode having “multiple copies” from different seasons
The plexignore file is properly named .plexignore (not .plexignore.txt) and currently has the file contents of
/*/Crossovers/*
  • Q:\Plex Libraries\Series\Super Sentai\S40 - Doubutsu Sentai Zyuohger (2016-2017)\Crossovers\[OZC-Live]Kamen Rider Ghost BD Box E24 ‘Appearance! The Mysterious Warrior!’ [1080p].mkv
  • Delete Files
  • Q:\Plex Libraries\Series\Super Sentai\S41 - Uchuu Sentai Kyuranger (2017-2018)\Crossovers\[OZC-Live]Kamen Rider Ex-Aid BD Box E24 ‘Be Ambitious and Go Together!’ [1080p].mkv
  • Delete Files
  • Q:\Plex Libraries\Series\Super Sentai\S33 - Samurai Sentai Shinkenger (2009-2010)\Crossovers\Kamen Rider Decade 24 - The Samurai Sentai Arrives v2.mkv
  • Delete Files
  • Q:\Plex Libraries\Series\Super Sentai\S01 - Himitsu Sentai Goranger (1975-1977)\Super Sentai - S01E24 - Blue Anger! Strong Greenmerang, Big Counterattack.mkv
That’s just 1 single episode, and the only valid one in this case where i’m trying to fix it is S01E24. Using square brackets is NOT an option. Why is this so difficult to get working reliably
Where is your .plexignore file? What is the path that your library is pointing to?
From the example in the support article you should be using *Crossovers/*.
Sorry for the delay, i have a spamfilter running on the mailbox linked to this account and it triggered based on “To unsubscribe from these emails” which is a line frequently used in dating spam mails.
I want my plexignore in the main series folder. I don’t want to use a global .plexignore folder. Docs indicate this should work but that’s not my experience
Have you tried using *Crossovers/* in your .plexignore file?
If you want this to apply to everything in the Series directory, place the .plexignore file in the root of Q:\Plex Libraries\Series.
If you want this to apply to only this Series, place the .plexignore file in the root of Q:\Plex Libraries\Series\Super Sentai.
