.plexignore stops working after agent "upgrade" (Plex Tv Series)
Server Version#:1.22.3.4392
Player Version#: Irrelevant
Plex Media Server Logs_2021-04-28_21-13-49.zip (7.4 MB)
The .plexignore has been working for years, right after I upgrade to new plex agent by “upgrade library” it detects the ignored media. In this case the ignore file was in in R:\Download\Barnserier\Silver Fang Pack\Silver Fang. The .plexignore file contained the code *Ginga/* and nothing else. Plex still detects the two folders Ginga Nagareboshi Gin and Ginga densetsu weed in same folder as .plexignore . I solved it by putting two .plexignore files in each of the two folders with the code Ginga* so it ignores the files instead of the intended folders. Still. Someting is wrong, plex should ignore the folder as before. It even says so in Special Keyword File/Folder Exclusion | Plex Support with the example:
Ignore directories called "Modified":
*Modified/*
Mvh Sebastian
