@croneter said:
@foghat
Trailers:
- I take it you are using a Plex Pass account? Otherwise no trailers
- Do you have the BETA version of PKC installed? Otherwise the fixes won’t work yet
- do trailers work if you deactivate the “ask for trailers”?
- how many trailers are set in the PKC Settings to be played?
- PKC debug logs from kodi side would help, see the wiki
Playstate is a known Kodi issue. Kodi screws up telling time in seconds or micro seconds at the very beginning of a video. Nothing that can be done here from PKC side
Yes I am plex pass, yes have 1.8.7 installed. No it does not work if I deactivate ‘ask to play trailers’. I have it set to play 2 trailers. I also have pre-roll setup. Trailers play fine on the default shield plex app and on my ios app.
Something is definitely flaky. I have two shields, both setup the same way. On both of them trailers do not play.
This morning I started a movie on one shield, no trailers and no sound once movie starts playing (not PKC related - no sound happens to me once in a blue moon), I reboot shield as this always fixes my sound issue. I start the movie again. This time I have trailers. Though it only plays one (even though I have it set for 2) and then plays my pre-roll and then the movie (sound and all).
So I am thinking great!, the reboot and relaunch of kodi fixed something (and maybe it only played one trailer because it is thinking the pre-roll is the second trailer?).
After the movie, I come upstairs and reboot my other shield. Still does not play trailers.
Go downstairs to the shield that played one trailer and start another movie - no trailers play.
At this point I have not idea what is going on. I am not sure if PKC debug logs are different than the kodi log? I have attached the kodi log after trailers do not play. If PKC debug log is something else, can you tell me where to find it?
Edit: and I should add, I only have plex set up to ‘include cinema trailers from new and upcoming movies in theaters’
I also tried turning on 'include trailers from movies in my library. That did not change the behavior.
EDIT 2: I am noticing the ‘information’ item still is not showing if I select the info button while viewing a tv episode from an ‘on deck’ widget. Still just shows play/resume and mark watched/unwatched. And selecting the episode still causes it to play instead of going the to detail/info screen (i have changed the default action from ‘play’ to ‘show information’)
Is it possible the updates did not actually get published to 1.8.7? As it seems the 1.8.7 functionality does not seem to be working. At least for me.
