PlexKodiConnect: Kodi Plex Integration Done Right
Hi guys, did a lot of searching but I guess I am just plain dumb. I don’t know which PlexKodiConnect (PKC) to (try to) install on my new Ugoos AM6B+ running CoreELEC-Amlogic-ng.arm-21.0-Omega-Generic.img on an SD card (with dovi.ko) stuck in the Ugoos. On the github PKC installation page I see the following four zipfile repositories to choose from:
Kodi Matrix Stable & Beta
Kodi Nexus Stable & Beta
Which is the one I want (least amount of headaches on the Ugoos?) Oh, and what’s the difference? Cheers :slight_smile:
@andybkma: the latest, so “Nexus” :wink:
I’m super excited for the Watchlist support! Really loving PKC, by the way.
Changelog
3.9.3 for Kodi Matrix and beyond (beta only)
Hi, am brand new to PKC on my new Ugoos AM6b+ with CoreELEC-Amlogic-ng.arm-21.0-Omega-Generic.img. I only have this CoreELEC version and the latest PKC Nexus 3.9.0 stable installed on the SD card. A coupla quick questions please if I may…
  1. I noticed that unlike the official Plex app or PM4K all the TV shows & Movies show up “inside” Kodi instead of opening up another app like with PM4K. Is this true or did I do something wrong?
  2. I only have your basic three Plex libraries : Movies, TV Shows & Other Videos. Piggybacking on Question 1, I can’t find my Plex “Other Videos” stuff… where is this hidden? With Plex official app and PM4K I have thumbnails of all the content that I have in my Plex “Other Videos” library but now I can’t find them “inside Kodi”. Left hand side under Kodi Movies I see a bunch of my movie posters (which I guess is my Movie library) and under TV Shows I see a bunch of my TV show posters (which would be my TV show library). But what I don’t see is my “Other Videos” library ?
  3. Backing out of PKC settings a few times I got a green/blue spinner for an extremely long time (default Estuary skin). I didn’t even change anything in PKC settings. Just looked around then backed out. Then the spinner for about 4 minutes, seems like the whole thing was frozen. This happened twice. Bug with CoreELEC?
@andybkma
  1. That’s the entire point of PlexKodiConnect :wink:. This enables you to use and Kodi skin, customizing the look of Kodi. You cannot do that with other Plex add-ons for Kodi.
  2. Check this link on how to separate different Plex libraries: Video Nodes and Skins · croneter/PlexKodiConnect Wiki · GitHub
  3. Yeah no idea, I have that too sometimes :slightly_frowning_face:. Haven’t been able to fix it.
Changelog
3.9.5 for Kodi Matrix and beyond (beta only)
  • Fix sync crashing with “plex_guid is not defined” #2072
3.9.4 for Kodi Matrix and beyond (beta only)
  • WARNING: You will need to reset the Kodi database!
  • Fix certain movie elements suddenly duplicating in library #2070
Hi all,
I have an Odroid N2 with CE and Kodi 20.5.
I have various Movies that are DoVi and with a fallback to HDR10. When first played with PKC the DoVi version tries to play, and as N2 is not DoVi compatiable the picture is terrible. The TV is DoVi compatible
If I stop the Movie and restart again the HDR10 version plays and all is good.
Is there a way to make PKC always use the HDR10 version first?
TIA
@gregeeh
There is option in Player Setting of Kodi to set supported HDR metadata
Settings>Player>Video> Supported HDR
If I recall correctly this would be the path for the setting
You can disable Dolby Vision from this setting if enabled, please check and update me if solves the issue or not
Thanks for your reply.
This is the only HDR setting under Player and can only be ON or OFF.
That’s because you’re using Kodi 20.5. AFAIK this is a feature of Kodi 21 Omega.
Sorry @panni but are you answering my question on the settings I have in Kodi or my other question regarding DoVi and HDR fallback?
Both. PKC doesn’t control your HDR settings. @abhi0077 hinted towards a setting that isn’t available in your Kodi version AFAIK.
Thanks for replying.
That setting is also not in Kodi 21. Installed it today on SD just to see.
I have that option available, and as @panni pointed out I have Kodi 21 and have this option in settings
Maybe the option is only available on devices that are DoVi compatible, hence why I’m not seeing the option on my Odroid N2.
Hi Everyone,
CE 21.0, Odroid N2 with latest PKC.
Whenever I play a trailer for any video I get this blue rectangle:
Does not happen with the Plex Client nor when using YouTube.
Any ideas what might be causing this?
TIA
No idea @gregeeh PlexKodiConnect does not in any way interfere with the actual video playback. This is either Kodi’s or Plex’ doing
Just figured it out. It’s an issue with Estuary Mod V2 Skin. You must have the play trailer option set to full screen to remove it.
Changelog
3.10.1 for Kodi Matrix and beyond
  • Fix auto skipping of e.g. intros or commercials getting stuck #2084
