@bigbadrabbit said:
Since PKC 1.1.10 i’m getting the “Sync had to skip some items because they could not be processed…” error.
Tried a full reset → error message pops up “check the log”
Did a full Kodi and PKC reinstall → sync works the first time but after a Kodi restart it won’t sync, video directories are empty and the “Sync had to skip…” error shows up.
Reinstall does not help because it does not delete the add-on settings. Always go to PKC settings - advanced - Full reset of db and PKC (in red), then 3x yes.
Edit - or was that your full reset?
Looks like your database got corrupted
With reinstall i mean:
Complete deletion of the Kodi application and it’s /Application Support/ folder. I mean deleting everything and begin with a complete fresh install of Kodi and then PKC via it’s repo.
@whitewidows said:
Im getting crashing and reboot during library scan, never completes.
Using Raspberry Pi 2, LibreELEC, 1000+ Movies, Reduced to 1 thread still does not help.
Logs please, otherwise I cannot help you. See wiki on github
Fresh libreELEC install, still crashing on sync
I believe this is the log you need
Try going to the PKC settings, sync options, and reduce both Limit artwork cache threads and Limit download sync threads to the bare minimum.
If Kodi still crasheds, then something about your libreELEC installation is off - Kodi cannot start another thread. I myself use a Raspi 2 with OpenELEC and never had any issues without the measures above. Any weird other Kodi plugins installed? Try downloading an official libreELEC build again and start from scratch by installing PKC at the very beginning if above does not work.
17:28:15 386.607605 T:1507840928 NOTICE: PlexKodiConnect Items -> add_update : Traceback:
Traceback (most recent call last):
File "/storage/.kodi/addons/plugin.video.plexkodiconnect/resources/lib/itemtypes.py", line 318, in add_update
self.run_add_update(item, viewtag, viewid)
File "/storage/.kodi/addons/plugin.video.plexkodiconnect/resources/lib/itemtypes.py", line 521, in run_add_update
artwork.addArtwork(allartworks, movieid, "movie", kodicursor)
File "/storage/.kodi/addons/plugin.video.plexkodiconnect/resources/lib/artwork.py", line 355, in addArtwork
cursor=cursor)
File "/storage/.kodi/addons/plugin.video.plexkodiconnect/resources/lib/artwork.py", line 438, in addOrUpdateArt
self.CacheTexture(imageUrl)
File "/storage/.kodi/addons/plugin.video.plexkodiconnect/resources/lib/artwork.py", line 300, in CacheTexture
self.addWorkerImageCacheThread(url)
File "/storage/.kodi/addons/plugin.video.plexkodiconnect/resources/lib/artwork.py", line 274, in addWorkerImageCacheThread
newThread.start()
File "/home/chewitt/LibreELEC.70-official/build.LibreELEC-RPi2.arm-7.0.1/Python-2.7.11/.install_pkg/usr/lib/python2.7/threading.py", line 736, in start
error: can't start new thread
cursor=cursor)
newThread.start()
This was a fresh official libreELEC install. No other plugins. Just PKC. Limits reduced. Still issues persists.
Is there a way to have KODI ignore articles (such as “The” ) when sorting a sync’d Plex database? I accidentally started a new thread below if you want to answer the question in there.
cursor=cursor)
newThread.start()
Going to try openELEC now.
@Grumpy70 - I know you are using libreELEC with PKC. Did you have similar issues?
Nope…all working here.
I am using Milhouse’s builds which change nightly, so maybe @whitewidows try a different build.
I will say when i first got the pi, i had to lower the Limit artwork cache threads and Limit download sync threads to the bare minumium or it would crash Kodi.
Ended up going through a few different cards before i found one that i didn’t need to change the settings.
