Plug-ins folder for Nvidea Shield
Hello,
Where is the Plug-ins folder located if the Plex server is running off Nvidea Shield??
I “could” be wrong here but I do not think that Plex/Shield gives you access to that folder.
The Shield TV FAQ has info on all the limitations:
https://support.plex.tv/hc/en-us/articles/221099648-Limitations-When-Running-Plex-Media-Server-on-NVIDIA-SHIELD
When running on the NVIDIA SHIELD, the Plex Media Server data directory is not currently user-accessible. Unfortunately, this means that it is not currently possible to manually install channels or plugins on the device. You can, of course, still install things through the normal Channel Directory.
Thanks both. It’s not possible
No plug-ins for me then!!
And isnt it possible to release a Plex Version for Nvidia Shield where the plugins folder is on free accessible storage? :confused:
Please, developer… check this out :slight_smile:
