Can u run Kometa on windows ?
Before anyone asks: Iām aware of the new watched/unwatched visuals ![]()
As announced, Iām working on the new theme engine; please bear with me.
Iāll ask for this at some point when youāre not so busy. Any chance of adding āScan Library Filesā to the Choose action for: panel for each library?
Whenever. No pressure.
That would be a very usefull feature - would also appreciate if implementable.
Oh good idea! Definitely a feature that could come in useful if it is possible.
Also quick question @panni. Iām not sure if itās a bug or if itās normal behaviour but if you have āBehave like official Plex clientsā enabled under Player UI should it still be honouring the options set under the Playback (user-specific) section?
Reason I ask is that I currently have āShow video chaptersā and āUse virtual chaptersā disabled however it still shows the option for chapters when pressing the up button.
At least for me It can sometimes get in the way when wanting to go up to the Skip Credits button as I have to sort of press the up button twice and then press down to get to it. Once to show chapters and then a second time to go up to the chapters to select them and then I have to press down for it to highlight/select the Skip Credits button.
I really hope that made sense as I was even confusing myself typing it. ![]()
Great suggestion, went right on my shortlist.
Hmm not sure I understand this completely. Youāre saying youāve enabled āBehave like official Plex clientsā (which currently enables accessing chapters via Down), but for shows where youāve disabled chapters the functionality is still enabled?
If thatās so, thatās a bug I guess. Iāll double check.
Yeah that is what I was trying to get at. Glad you mostly understood. Sorry about that. ![]()
FYI, yes, development is still going on. Thereāll be a pretty massive new beta in the coming days. Iāve built the aforementioned templating engine.
Iāve unfortunately come across another bug, using 0.7.9 beta 7.1 (and beta 6.2 as I forgot to update to 7.1 apparently) I started the next episode playing from the play button on the season select screen, then when backing out of the playing episode to the TvSeries season select screen and pressing the play button I donāt get any option to continue from where I left off or start from beginning like you would usually get and the episode doesnāt play.
There are no errors in the log and it just seems like the play button doesnāt respond to clicks \ presses.
These are the log lines from episode stop to attempting to play again, I donāt think thereās anything useful in them though:
2024-07-04 20:49:22.331 T:1507 info <general>: script.plex: VideoPlayerWindow: Session ended - closing (ID: 140618191035856)
2024-07-04 20:49:22.331 T:1507 info <general>: script.plex: VideoPlayerWindow: Closing
2024-07-04 20:49:22.332 T:1637 info <general>: script.plex: BGThreader: (queue.0:worker.0): Active
2024-07-04 20:49:22.332 T:1637 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/hubs/continueWatching/items?X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.334 T:1638 info <general>: script.plex: BGThreader: (queue.0:worker.1): Active
2024-07-04 20:49:22.334 T:1638 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/hubs/home/recentlyAdded?type=1&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.335 T:1639 info <general>: script.plex: BGThreader: (queue.0:worker.2): Active
2024-07-04 20:49:22.336 T:1639 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/hubs/home/recentlyAdded?type=2&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.336 T:1507 info <general>: script.plex: Notification: xbmc Player.OnStop {"end":false,"item":{"episode":1,"season":1,"showtitle":"Pseudo Harem","title":"ē©čŖć®å§ć¾ćļ¼","type":"episode"}}
2024-07-04 20:49:22.417 T:1638 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/library/sections/10/all?viewCount>=1&type=8&sort=lastViewedAt:desc&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.422 T:1638 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/hubs/sections/15/continueWatching/items?X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.451 T:1639 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/library/sections/15/all?type=4&sort=originallyAvailableAt:desc&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.466 T:1639 info <general>: script.plex: Hub tv.recentlyaired.15 updated - refreshing section: 'Anime-Premiere'
2024-07-04 20:49:22.466 T:1639 info <general>: script.plex: HUB: tv.recentlyaired.15 [tv.recentlyaired](10, None)
2024-07-04 20:49:22.530 T:1639 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/hubs/home/recentlyAdded?type=2§ionID=15&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.533 T:1639 info <general>: script.plex: Hub tv.recentlyadded.15 updated - refreshing section: 'Anime-Premiere'
2024-07-04 20:49:22.533 T:1639 info <general>: script.plex: HUB: tv.recentlyadded.15 [tv.recentlyadded](0, None)
2024-07-04 20:49:22.533 T:1639 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/library/sections/15/all?type=2&viewedOrInProgressLeafCount=0&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.548 T:1639 info <general>: script.plex: Hub tv.startwatching.15 updated - refreshing section: 'Anime-Premiere'
2024-07-04 20:49:22.548 T:1639 info <general>: script.plex: HUB: tv.startwatching.15 [tv.startwatching](10, None)
2024-07-04 20:49:22.562 T:1639 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/library/sections/15/all?type=2&lastViewedAt<=-6w&lastViewedAt>=-5y&unwatchedLeaves=1&viewCount>=1&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.579 T:1638 info <general>: script.plex: Hub tv.inprogress.15 updated - refreshing section: 'Anime-Premiere'
2024-07-04 20:49:22.580 T:1638 info <general>: script.plex: HUB: tv.inprogress.15 [tv.inprogress](2, None)
2024-07-04 20:49:22.580 T:1638 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/library/sections/15/all?type=2&unwatchedLeaves=1&genre=9217&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.630 T:1638 info <general>: script.plex: Hub tv.moreingenre.15 updated - refreshing section: 'Anime-Premiere'
2024-07-04 20:49:22.630 T:1638 info <general>: script.plex: HUB: tv.moreingenre.15 [tv.moreingenre](10, None)
2024-07-04 20:49:22.638 T:1638 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/library/sections/15/all?type=2&unwatchedLeaves=1&audienceRating>=7.0&sort=audienceRating:desc&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.652 T:1638 info <general>: script.plex: Hub tv.toprated.15 updated - refreshing section: 'Anime-Premiere'
2024-07-04 20:49:22.652 T:1638 info <general>: script.plex: HUB: tv.toprated.15 [tv.toprated](10, None)
2024-07-04 20:49:22.653 T:1638 info <general>: script.plex: API: GET https://192-168-5-205.7267e5b37cd04f37ba9ee5cdcbab1a65.plex.direct:32400/library/sections/15/all?sort=lastViewedAt:desc&unwatched=0&viewOffset=0&type=4&X-Plex-Token=****&X-Plex-Container-Start=0&X-Plex-Container-Size=10
2024-07-04 20:49:22.676 T:1639 info <general>: script.plex: Hub tv.rediscover.15 updated - refreshing section: 'Anime-Premiere'
2024-07-04 20:49:22.676 T:1639 info <general>: script.plex: HUB: tv.rediscover.15 [tv.rediscover](3, None)
2024-07-04 20:49:22.676 T:1639 info <general>: script.plex: BGThreader (queue.0:worker.2): Idle
2024-07-04 20:49:22.810 T:1638 info <general>: script.plex: Hub tv.recentlyviewed.15 updated - refreshing section: 'Anime-Premiere'
2024-07-04 20:49:22.810 T:1638 info <general>: script.plex: HUB: tv.recentlyviewed.15 [tv.recentlyviewed](10, None)
2024-07-04 20:49:22.813 T:1638 info <general>: script.plex: BGThreader (queue.0:worker.1): Idle
2024-07-04 20:49:23.386 T:1637 info <general>: script.plex: BGThreader (queue.0:worker.0): Idle
Can you create a ticket on github, please? Iāll likely need further information and donāt want to clog the thread up ![]()
Edit: Aaaah I think I got it. You started the episode by pressing play on the TV Show screen, not the episode screen. And yeah, can confirm, after exiting the player and trying the same thing again, the play button doesnāt do anything. Noted, thank you!
Let me get the next beta out with the huge core changes, then Iāll tackle some of the last bugs.
First of all GOOD JOB!!! @panni
Then i want to share that i wanted to start a separate spinoff of that mod with more modern theme (a la current plex apps modern theme)ā¦
So far i have modified only details screens But i think is not so badā¦
Here is previewā¦
My aim is to not be so customizable but to be with modern style aligned to Plex actual style (with some differences ofcource)ā¦
Nice!
Wait a couple of days until the next 0.7.9 beta.
Youāll be able to fully customize PM4K and youāll even be able to release your own custom theme to the public, without having to fork anything.
And Iāve adapted the new (button) themes to all views, not just the video player.
Iāll also add a wiki entry as to how the new templating engine works.
Cool! However will it be possible to extend the python libraries too? Since my mod requires it. I have added extensions for movie editions, image bluring and so onā¦
Without that there is no chance to achieve that viewā¦
Custom blurring shouldnāt be an issue I guess, and for the other extensions: If they make sense in a generic way, Iām certainly open to pull requests.
But letās talk when weāre there. Maybe open up a Discussion on the Github repo surrounding custom theming/extensions.
Edit: Iād prefer not to have a fork of a fork to be honest ![]()
Edit 2: I mean, a dynamic python library loader isnāt out of the question, either, if itās really necessary.
Just did some tests - itās not as easy as prepending sys.path with userdata/addon_data/script.plexmod/lib (probably due to the fact that Kodi uses RestrictedPython).
What works, though, python 3.4 and up:
from kodi_six import xbmc, xbmcvfs, xbmcaddon
import importlib.machinery
import importlib.util
# Import mymodule
loader = importlib.machinery.SourceFileLoader( 'testoverride', os.path.join(xbmcvfs.translatePath(xbmcaddon.Addon().getAddonInfo('profile')), "lib", "testoverride.py"))
spec = importlib.util.spec_from_loader( 'testoverride', loader )
testoverride = importlib.util.module_from_spec(spec)
loader.exec_module(testoverride)
testoverride.bobo()
So I could either build a custom importer, or I could simply let you create a āmoduleoverrides.pyā, that modifies PM4Kās code on the fly, monkeypatch-style.
Maybe thereās other options, Iāll investigate.
Edit: Yeah, thatāll probably work, as in:
import os
import sys
# Import mymodule
sys.modules['lib.windows.home'] = testoverride
ā just tested:
script.plex: ERROR:
Traceback (most recent call last):
File "C:\Users\panni\Kodi_21\portable_data\addons\script.plexmod\lib\main.py", line 167, in _main
windowutils.HOME = home.HomeWindow.create()
AttributeError: module 'testoverride' has no attribute 'HomeWindow'
Which is perfect. Iāll keep that branch and will iterate on it later.
Edit 2: So I could look for any files existing in that external lib folder and load them dynamically, overriding anything PM4Kās original source does.
For anyone curious, 0.7.9-beta11 WIP on github. Sorry panni if Im spoiling anything, but I really wanted to highlight how freaking awesome your work is! Thanks a billion times, again.
Leaker! Burn him/her for linking public information! ![]()
The currently pushed version (not released here yet) is usable and stable, Iām trying to make unwatched/watched indicators more dynamic (theme/settings-based without having to duplicate XML markup; adding the new black/white watched indicators as a new default), and a couple of cleanup tasks.
Weāll see how far I get on the weekend, expect a beta soon. And at lot of testing will be required by you guys
(massive rewrites included)
Edit: Oh yeah, and a lot of CoreELEC-related workarounds. Not excited. Kodi != CoreELEC Kodi more often than not, unfortunately.
Edit 2: corrections
Iām going to wait for the beta although I was tempted. As a CoreELEC user myself, itās disappointing that youāre running into problems with it. Tbh, Iām realising that Iām not the most observant user but I think Iāve seen the judder after skip issue.
