PM4K / PlexMod for Kodi (18, 19, 20, 21, 22+)
The artwork once generated for a client resides in PhotoTranscoder folder, therefore it is only generated again if client or user changes, you can increase the speed by using SSD and placing specially the PhotoTranscoder folder in it, If you have older system and you don’t restart it much often you can do what I adopt is by putting the PhotoTranscoder folder in RAM Drive, in Linux its very easy to mount ram drive and give permissions to plex:plex just search the internet.
But by placing the PhotoTranscoder folder in non-volatile device will be huge CPU Taxing, but for once for a client, if you open the same meta again by same client and user it will be so quick.
While technically true, it doesn’t really matter, as most PMS’s will keep their whole sqlite DB in memory, and then, it’s really fast (also depending on the system the PMS is running on, of course).
You are right, though. We don’t need to send the timeline forcibly every second, anymore. Since I’ve altered how we report the timelines when any important events occur (stop, seek, pause, resume), a couple of versions ago, we pretty much guarantee to send the right one and thus guaranteeing the right resume time reported. I’ll add it to my list for 0.8.0!
Thank you so much panni, that will be a welcome change indeed. :heart_eyes:
0.7.9-prerelease3.2: script.plexmod.zip (2.8 MB)
Temporary Changelog:
  • Home-Hubs/Library-Hubs: Try correctly reselecting the last selected item after item progress has been made and we’re revisiting home (hubs update)
Yes. This is on the PMS side, though. The client itself caches those images as well, via the Kodi image cache. That one needs to be fast as well, for the loading to be quick.
Please report back if that fixes your issues so I have a sane default for that setting for the final release, thanks! (I’ll probably add 50ms on top of that just to make sure)
I’m trying to remap a certain command on my remote.
but which command do I need to use to show this? (normally you need to do this during playback => Settings => Show Stream Info)
Sorry for the green background, it was a DV media file during the playback
I thought it would be playerprocessinfo but that one shows something else.
You can’t map that at the moment.
Edit: Oh wait, no, it reacts to button code 61519, you can try mapping that.
Has anyone noticed that the grey buffer indicator doesn’t always show up in the OSD? I find it shows up inconsistently. Not sure if a bug but thought i’d just advise.
Depends on the mode (Directplay vs DS/Transcode) and the size of the buffer in relation to the size of the file. With a 50MB buffer, the width of the grey bar can be less than 1px if your video file is 15GB in size for example.
We take the buffer amount from kodi’s internals and translate them to our buffer bar. You can open the stream info to see how full it is.
Ah that makes sense, is there perhaps a better way to represent the buffer visually speaking? I realise it wouldn’t make sense mathmatically speaking but it would be nice to know that there’s something ahead. I am direct play 99% of the time.
Do I press the O key to do that? I don’t have a keyboard connected so perhaps an option to map it in the UI to a button would be good? I see I can do it with the Keymap Editor though so maybe not necessary.
You can just open the options and scroll down til the end. No need to map it.
And yeah, maybe it’s possible to have a minimum width for the buffer line. Not sure right now how I’ve implemented it. I’ll put it on the list.
A feature request (For 0.8.0?) Can you add a filter for subtitle-language?
(So I can see all the movies and all the tv-shows that has Swedish subtitles)
I can do this in the official Plex for Android (at least for movies, but not for tv-shows)
Should be possible for movies at least. For shows it’s way more complicated. The only way to do this properly is to fetch the metadata for all episodes of a show and find all matching subtitle languages. Probably in the “not feasible” area for libraries. A workaround could be a subtitle language filter for episodes, then you can visit the show from there. Not great, though.
Yes, that would work for me! (a subtitle language filter for episodes)
0.7.9 - March of the ELECphants :elephant:
I’ll try keeping this short this time, as the changelog blows this post out of proportion.
*ELEC
We’ve had an influx of CoreELEC users for a while, especially on the Ugoos AM6B+, which brought its own issues. CE doesn’t necessarily behave like other Kodi clients do, so in order for the core functionality of PM4K to work for those clients, we had to introduce a couple of special cases and a lot of testing, to find the right solutions.
Those solutions aren’t pretty, but work, so expect a little wonkyness here and there. Ideally, CoreELEC would fix the root causes themselves, but until they do, PM4K will at least work for those people.
Templating
As outlined in more detail here, we’ve added our own dynamic jinja2-like templating language. With this we have the freedom to not having to use static XML files, thus reducing overhead, repetition, error-proneness and enabling us to do things, we weren’t able to do before.
There’s two things where you’ll notice this: The 2024 watched-checkmarks, which are supported now besides the older styles, and the “smaller aspect ratio” support (16:10, 4:3), without stretching the UI. Ah, and the theme setting now applies to all player UI’s, not just Videos.
Bugfixes, UX-Improvements, Features
Honestly, there’s too much to properly pick the right ones for this section. If you’re interested, try reading the changelog :smiley:
Sidenote
I’m still planning to take the time to write up a little Wiki explaining the ideal setup of PM4K in your Kodi environment, as well as going into more detail about some of the non-obvious features of PM4K.
Thanks go out to everyone who participated in this release, and also the translators over at our POEditor project (German, Spanish and Chinese are 100% translated).
As always, thanks to The Squad™: @sonofdibnah @ecsjjgg @jamal2367 @THGhost @bowlingbeeg @Buttzy10169 @SmarthyMcFly @pl37919 @FortKnox1337
Buy Me a Coffee at ko-fi.com
And now to the fun part: The (already shortened)
Changelog
  • Episodes: After fully watching the last episode of a season, select the next unwatched episode of the next season, automatically, after returning to the episodes view
  • Episodes: Carry progress data as long as we’re visiting (nested) episodes views
  • Episodes: Clear progress data after filling episodes when opened without nesting (episodes or postplay)
  • Episodes: Correctly select next-up-episode even if we had progress data
  • Episodes: Correctly show episode thumbnails at their 16:9 ratio
  • Episodes: Correctly update unwatched counter in seasons list after marking an episode watched
  • Episodes: Don’t change focus after selecting a new episode (might need a better fix)
  • Episodes: Don’t reselect current season in seasons view after returning from visiting another season
  • Episodes: Fix badly reported resume states
  • Episodes: Fix episodes not playable after returning from playback
  • Episodes: Fix focus handling (don’t refocus already focussed elements)
  • Episodes: Fix focussing after playing something in a different season
  • Episodes: Fix no related shows shown; broken for half a year
  • Episodes: Fix rare timing issue (with possible crash/freeze) when play was pressed before theme music started playing (thanks @MikeTeavee for reporting and testing the fix)
  • Episodes: Fix refocus handling after visiting a sub-season
  • Episodes: Fix round robining too early after returning from playback and pressing left after watching the first episode
  • Episodes: Fix wrong top scroll when returning to episodes screen after visiting sub-season
  • Episodes: Harden selectEpisode logic further
  • Episodes: Only redirect to seasons when returning from playback (reinit)
  • Episodes: Properly reselect play button if possible
  • Episodes: Visually fix resume point still showing after rewinding to a non-resume-worthy point (<60s) in a video that had a resume point
  • Episodes: When watching multiple episodes in a row, completely, until the end of the season, select the last episode in the season when returning from playback
  • Episodes/Movies: Fix play button not working after cancelling the resume dialog; fix play button not working after returning to view after direct playing from home
  • Episodes/Movies/Libraries: Don’t allow multiple presses of play to avoid issues
  • Episodes/Postplay: Fix behaviour when visiting episodes view from postplay
  • Home: Allow hiding specific hubs via hubitem context menu
  • Home: Avoid mis-selecting a hub item after watching something and returning to the hub, after updating the hub and a different selection has been made in the meantime
  • Home: Avoid section button “jumping” on reInit after visiting a library
  • Home: Bifurcate library dropdowns
  • Home: Correctly re-enable home updates even if we’re playing, after coming back from screensaver or sleep
  • Home: Disable updates when screensaver activated
  • Home: Don’t refresh stale sections while we’re not the active window; might improve UI performance after watching something
  • Home: Fix extremely long/indefinite reload when revisiting home after watching something from another library for longer than 5 minutes
  • Home: Fix setting correct background when round-robining hubs
  • Home: Implement library features “Scan Library Files”, “Empty Trash”, “Analyze” for admins
  • Home: Properly support cancelling library reordering (reverting to the previous order)
  • Home: SectionHider: After hiding a section, go to the previous one
  • Home: SectionMover: Stay on current section after moving
  • Home: update On Deck hubs after revisiting home, not before
  • Home: Wait 1 second before continuing (block input) after wake event (default); 5 seconds for CoreELEC (default)
  • Home: When a hub goes missing (e.g. continue watching gets emptied) after reinit, focus next best valid hub, if a hub was focused before
  • Home: When onWake is set to restart PM4K, close all active dialogs and non-home windows before exiting
  • Home/Hubs: Try correctly reselecting the last selected item after item progress has been made and we’re revisiting home (hubs update)
  • Home/Hubs: When round-robining is enabled, limit the amount of items fetched to 250 (default); if the hub exceeds this value, the rest of the items are lazy loaded as before
  • Home/Restart-after-wake: Prevent API calls when we’re closing all windows and returning home to restart the app
  • Home/Settings: Fix description for EZ mapping
  • Home/Settings: Set home dirty when changing the option to show/hide path mapping indicators
  • Home/Settings/Theming: When setting a theme-relevant setting, restart home
  • Photos: Correctly focus play button on OSD open
  • Player: Properly honor previous paused state when switching streams during transcode session (now pausing onAVStarted instead of onPlayBackStarted)
  • Player/Audio: Fix zero-duration error; fix seeking impossible
  • Player/Episodes/Seekdialog: Always correctly select the currently playing item in the current playlist
  • Player/Episodes/Videoplayer: Avoid blocking play button based on wonky BGM state
  • Player/Episodes/Videoplayer: Before starting playback, wait for BGM to finish being handled
  • Player/Music: Fix broken shuffle handling (hopefully)
  • Player/PlaybackState: Allow forcing a timestamp
  • Player/PlaybackState: Avoid using the player’s current time when reporting a stopped state via the tick() method; might fix resume issues on CoreELEC when switching audio streams that need transcoding; add logging
  • Player/PlaybackState: Only store progress for episode view if updatePlaybackState has accepted and sent our new timestamp
  • Player/SeekDialog: Show chapters when pressing down with OSD
  • Player/SeekPlayerHandler: Possibly harden further against bad timeline events
  • Player/Settings/Player UI: Add option to show OSD instead of skipping chapters when pressing up/down without OSD (Default: On) (called “Behave like official Plex clients”)
  • PlexPlayer: Music: Allow directplay of high resolution audio (e.g. FLAC >= 192 kHz)
  • PlexPlayer: Music: When transcoding is necessary, use http/mp3/mp3 for compatibility and seeking reasons
  • Postplay: Allow resuming in-progress episodes
  • Postplay: Fix cosmetic "API: ERROR: FATAL: Container address is not an expected path: "
  • SeasonsMixin: Don’t auto-select unplayed specials/season 00
  • SeasonsMixin: Select the first unwatched season by default
  • SeekDialog: Allow ACTION_PAGE_DOWN and ACTION_PAGE_UP to bring up the OSD when Behave like official Plex clients is active
  • SeekDialog: Allow for seek-back on resume after pause (only Direct Play)
  • SeekDialog: Blur chapter preview images if wanted
  • SeekDialog: Fix issue with time fields not updating in OSD when transcoding video (thanks @bowlingbeeg)
  • SeekDialog: Fix Kodi UI shining through when pressing INFO
  • SeekDialog: Fix player settings scrollbar visible between native Kodi settings dialog fades (returning from subtitle offset adjust for example)
  • SeekDialog: Normalize marker data before modifying it
  • Seekdialog: Only react to DOWN with OSD shown if we should behave like official Plex clients and we want/have (virtual) chapters
  • SeekDialog: Postplay: Fix replay error/issue
  • SeekDialog: Re-evaluate MediaDecisionEngine decision when changing selected streams during playback; this allows switching between DirectPlay/DirectStream/Transcode, on the fly, based on the selected streams
  • SeekDialog: Reduce skip-button “jumping” just before auto skipping a marker
  • SeekDialog: Refocus playlist button after closing playlist dialog, after opening it more than once
  • SeekDialog/CurrentPlaylist: Honor no TV spoilers setting as well
  • SeekDialog/Player: Don’t restart the video when changing audio or subtitles (possibly even video, not tested), if not necessary
  • SeekDialog/Player: Fix resume-on-start sometimes not working when an embedded subtitle stream was selected
  • SeekDialog/Player: Report selected streams correctly to PMS when switching streams in DirectPlay mode (activity/sessions tab in PlexWeb)
  • SeekDialog/PPI: Correctly position CPUUsage when scaled
  • SeekDialog/VideoSettings: Hide fade backdrop when we’re using skin.plextuary
  • SeekDialog/VideoSettingsDialog: Don’t fade background when OSDBackgroundPause isn’t activated in plextuary; never fade background when SliderDialog is active (audio/subtitle offset adjustments), regardless of the skin used
  • Audio: Fix transcoding not working
  • Audio: Support direct play of high-res audio (<= 384 kHz)
  • Audio/CurrentPlayList: Allow round-robining
  • Audio/CurrentPlaylist: Close current playlist view when pressing back/previous menu with current playlist view open instead of closing the music player
  • Audio/Playqueues: Fix issue were track would skip back to the previous one
  • Audio/Playqueues: Generic fixes
  • Boot: Force home before starting via plugin mode (Program Addons, My Addons, Shortcuts)
  • Core: Add customized templating engine
  • Core: Add info to splash in log whether we need scaling or not, and the current aspect ratio
  • Core: Add our own ibis-3.3.0 fork as a library
  • Core: Add singleton from tendo library; add LICENSE; make singleton py2 compatible (hopefully)
  • Core: Add the ability to use an addon-supplied CA-certificate bundle for plex.direct connections (might be slightly less resource-intensive; new default; non-plex.direct connections will use the system bundle), the system bundle (old default), or a custom bundle
  • Core: Allow going home using a mapped button (thanks @Rick_Williams for testing)
  • Core: Change the way we use onAction introduced with the goHome button
  • Core: Detect whether we’re using skin.plextuary
  • Core: Dropdown with header: Limit vertical size, enable scrolling
  • Core: Dump all user settings into the DEBUG log if requested (private information masked)
  • Core: Fix certain network related issues
  • Core: Fix hang after sleep/wake when network isn’t immediately available on CoreELEC
  • Core: Fix No data error upon startup when “Use new Continue Watching hub” is enabled
  • Core: Fix usage of collections.Iterable with Kodi python > 3.9
  • Core: Make DEBUG_LOG calls cheaper in case DEBUG isn’t enabled
  • Core: Revert 2023 change to tick every 100ms; tick every 1 second
  • Core: Separate version info and global property handling from util.py into kodi_util.py
  • Core: Store active state in global property for skin.plextuary to detect whether we’re the active window and not minimized
  • Core: Support new JSON based settings (we had something similar before for lists)
  • Core/AddonSettings: change stepping for non-local-check timeouts from 0.1 to 0.5
  • Core/AddonSettings: Correctly honor dynamic backgrounds setting
  • Core/AddonSettings: Increase skip_intro_button_show_early_threshold1 from 60 to 70 seconds (by default)
  • Core/AddonSettings: Set max_retries=3 (default) for HTTP/HTTPS adapters, possibly fixing section refresh failing after power states (hibernation) (thanks @stigger)
  • Core/AddonSettings: Split connect and read timeouts for Plex and Plex.tv connections; correctly set default max_retries to 3; New defaults: Plex (connect: 5s, read: 10s), Plex.tv (connect: 5s, read: 20s)
  • Core/Boot/Entrypoint: Make entrypoint leaner by only importing what’s necessary
  • Core/Boot/Entrypoint: Use both tenga.singleton and global “started” property on Window(10000) to determine whether we’re already running
  • Core/Boot/Kiosk: Allow delaying autostart/kiosk-mode; allow manual immediate start when requested
  • Core/Cache/Settings: Disallow writing (and showing) cache settings from within the plugin when installed from the official Kodi repository and we don’t have the modern API
  • Core/GUI/Templating: Smaller aspect ratio support (16:10, 4:3, …)
  • Core/Main: Make absolutely sure we never run more than one instance at a time (via tendo.singleton locks)
  • Core/Mainloop: Clean up global properties
  • Core/MyPlex/UserSettings: Use cached user/account while waiting for plex.tv response; fixes episode playback errors with bingeMode setting
  • Core/Networking: Fix certain queries not timing out (thanks @evertonmdz for testing)
  • Core/Networking/MyPlex: Adhere to max_retries when querying myplex; adhere to PLEXTV_TIMEOUT_READ (default: 20s) when doing so (used LONG_TIMEOUT=20 as a fixed value before)
  • Core/Networking/MyPlex: Retry myplex query on account initialization 4 times; use util.LONG_TIMEOUT (default: 20s) for data and util.TIMEOUT (default: 5s) for connecting
  • Core/PlaybackManager: Allow ACCOUNT.ID to be None to not fail on pbs.bingeMode in certain (rare) situations
  • Core/Plugin: Make plugin entrypoint much leaner; remove old directory based play() feature; move ensureHome() to kodi_utll.py
  • Core/Reactivate/Maximize: If unable to reactivate plugin, exit cleanly
  • Core/SeekDialog: Workaround for seek issue on Ugoos am6b+ (On the Ugoos am6b+ after seeking it can take 2-15 seconds for audio to start while the video is playing. Playing the same file using the default kodi player does not exhibit this issue. Changing to use the executebuiltin(Seek) solves this issue.) thanks @bowlingbeeg
  • Core/Settings: Add setting to System tab to dump all user settings
  • Core/Settings: Allow setting DEBUG on the fly, without restarting the addon
  • Core/Settings: Backport old separated boolean settings to multioptions
  • Core/Settings: Implement MultiOptionsSetting
  • Core/Settings: Implement theme-relevant settings flag; reapply theme if necessary after exiting settings and revisiting home
  • Core/Templating: Allow full context overriding by using addon_data/script.plexmod/context_overrides.json (see lib/templating/context.py for structure)
  • Core/Templating: Recompile templates if we’re missing XMLs; fixes addon not starting after upgrade without theme version change
  • Core/Theming: Allow overriding theme definition/defaults by supplying theme_overrides.json in userdata/addon_data/script.plexmod; see /lib/templating/context.py for the data structure
  • Core/Theming: When rendering templates, show kodi progress dialog
  • Core/Windows: Fix “Go to Home to {library}”; properly select and focus library in section list
  • Dropdown/Libraries: Fix visual scrolling issues on dropdowns with many items (e.g.: Genres)
  • Dropdowns: Be smarter when we’re trying to display a dropdown that’s out of bounds
  • FireTV: Fix timeFormat (at least in InfoView)
  • Fix seek issue with CoreELEC devices (thanks @bowlingbeeg)
  • GUI: Clean up interface by removing most button focus zoom animations
  • i18n/Chinese: Fix broken translation (incomplete)
  • i18n: Update Chinese translations (thanks liquidion, wabisabi, x1ao4)
  • i18n: Update German translations (thanks fuchs21, Martin)
  • i18n: Update Spanish translations (thanks Deci8belios, Donovan_000)
  • Indicators: Improve indicators resolution; add missing image
  • Kodigui: Support dialog and window close signals
  • Libraries: Fix play all and shuffle all buttons
  • Library: Add “Episode Date Added” sort; rename “Name” sort to “Title”
  • Library/Music: Support Tracks as type on Music libraries; partially fixes #133; should fix #132
  • Main/EventLoop: Allow setting a tickrate different than 1 Hz
  • Movies/Episodes: Auto-scroll long summaries
  • Music Libraries: Fix filters erroring
  • Music: When stopping playback with open current playlist, close audio player window as well
  • MyPlexAccount: Fix isAdmin based on homeUser (when caching home users)
  • Settings: Add CONTEXT_MENU to clear bound home button to description
  • Settings: Add MultiUAOptionsSetting (a user aware variant of MultiOptionsSetting)
  • Settings: Add setting “Action on Wake event” (none, restart pm4k, wait Xs)
  • Settings: Add setting for Hi-Res Music (default: on)
  • Settings: Add setting to allow a delay for the autostart/kiosk-mode
  • Settings: Add setting to enable or disable factor based scaling of modern watched indicators based on poster size (default: on)
  • Settings: Add setting to only allow seek-back on Direct Play
  • Settings: Add setting to only seek-back after a certain amount of time in paused state
  • Settings: Add setting to seek-back on pause instead of resume
  • Settings: Add setting to set seek-back on resume after pause (100ms, 250ms, 500ms, 750ms, 1-60s)
  • Settings: Add user-setting to never show Post Play (default: off)
  • Settings: Allow clearing home button mapping using CONTEXT_MENU/long press
  • Settings: Disable “Stop video playback on screensaver” by default
  • Settings: Focus setting categories when pressing back while inside a category instead of immediately backing out
  • Settings: Implement new watched/unwatched status setting (default: Modern (2024))
  • Settings: Move “Behave like official Plex clients” further up
  • Settings: Move “Player Theme” setting to Main section and rename it to “Theme”
  • Settings: Move “Stop video playback on idle after” and “Stop video playback on screensaver” settings to Video Player tab
  • Settings: Move autostart/kiosk-mode to Main (was in: System)
  • Settings: Move Theme selection above Indicators
  • Settings: Post play Auto Play: Honor postplay timeout in setting description (addonSetting; default: 16s)
  • Settings: Re-arrange settings; add “User Interface” tab; move a lot of settings from Main to User Interface
  • Settings: Remove visually “annoying” last main section item bottom border
  • Settings: Rename “Hide black backdrop in inverted watched states” to “Hide background in modern indicators”
  • Settings: Rename Player UI to Video Player
  • Settings: TV Spoiler settings: Add setting to hide chapter preview images
  • Settings: Unify TV spoiler settings further
  • Settings: Update hubs round robin description, add warning
  • Settings: Use unicode literals
  • Settings/Audio/AC3/DTS: Change setting options from 2.1+ and 5.1+ to >2.0, >2.1, >5.0, >5.1 to allow for more fine-grained control
  • Settings/Home-Map-Key: Show proper dialog while remapping; make use of skin.plextuary-pm4k-1.1’s no-icon-dialog
  • Settings/MultiOptionsSetting: Keep original options order when displaying currently selected options
  • Settings/Player UI: Test new MultiOptionsSetting for a couple of Player UI button visibility settings (should auto-migrate over from old boolean settings)
  • Settings/Player: Add “Skip intro” and “Skip credits” to button options, allowing per-user control of whether marker action buttons should be shown or not (default: On)
  • Settings/Player: Make “Show buttons” setting user aware
  • Settings/TV/Spoilers: Make allowed TV spoilers for specific genres configurable
  • Settings/Video: Streamline playback features and video codecs to reduce the amount of settings available
  • AddonSettings: Add setting for tickrate (default: 1 Hz, min: 0.5 Hz, max: 10 Hz)
  • AddonSettings: Add setting to Cache Templates (default: on); Add setting to always recompile templates on start (default: off)
  • AddonSettings: Add setting to choose the CA-certificate bundle (system, plex.direct (default), custom (userdata/addon_data/script.plexmod/custom_bundle.crt)
  • AddonSettings: Add setting to specify the limit for round-robining hubs (default: 250, safe tested on SHIELD: 1000)
  • AddonSettings: Increase CoreELEC resume seek wait to 250ms by default (was: 200ms); thanks @panaitwebbos for testing
  • AddonSettings: Reset default Plex Requests timeout to 5s (was 10s); increase maximum to 60s (was 30s)
  • Signals: Check whether we’ve actually registered a signal before trying to disconnect it
  • Templating: Retry writing a template to disk once
  • Templating: Try making sure the XMLs actually have been written (sadly xbmcvfs.File doesn’t allow flush/sync())
  • Templating/Kodigui: Harden against corrupted XML files; recompile templates if encountered in any window/dialog
  • Templating/Postplay: move hubs up a little (scaled)
  • Templating/Watched_indicators: Implement factor based scaling of modern watched indicators based on poster size
  • Theming: Apply button themes to all views
  • Theming: Cache templates by default, making subsequent theme-related changes blazing fast (cache clears after restarting PM4K and is filled again when recompiling templates)
  • Theming: Implement new 2024 watch status
  • Theming: Make watch status indicator handling fully dynamic (templated)
  • Theming/Playlists: Use different watched indicator location
  • Tracks: Select last played track on window reinit
  • TV Shows: Fix play button not working after returning from playback on TV Shows/Seasons screen
  • Videoplayer/External: When using external player handle Ended events as always stopped manually
  • VideoPlayer/Postplay: Fix vertical positioning of hubs to be about the same as in Movie/Preplay view
  • Videoplayer/Postplay/Episodes/Movies: Try fixing rare timing error when clicking a role/actor
  • VideoPlaylists: Fix returning to playlist after manually stopping a video
  • VideoPlaylists: Properly select first unwatched item if possible; correctly set current item after returning from watching more than one
0.7.9 is being pushed to the Don’t Panic repository soon. pushed to the Don’t Panic repository.
See 0.7.9-rev2 for zip.
Edit: Damn, I need to do shorter iterations next time. The size of this changelog doesn’t make any sense :smiley:
Well done.
Forgive me for not reading the changelog but I lived with each one as they happened and could barely keep pace with them then!
I installed version 0.7.9 for testing, but I found that in many places the translations were not successfully applied. The Chinese translations in POEditor have been 100% completed, but in version 0.7.9, there are still many translated contents that are displayed in English rather than Chinese. Perhaps you can check where the issue lies.
Additionally, the section names on the hub page are all in English. It seems that there is no translation option provided for them in POEditor, and they are also not respecting the user’s language settings.
There is a bug in playback.
Once I stop movie, then I return back after a few minutes, it is resuming not from where you stopped it.
Also, I noticed, when I resume back to the movie, the picture is stuttering, frame rate is not shown correctly.
Anyway thanks for your great work!
Weird, I’ll check. I simply exported the translations you guys did, from poeditor.
I’ll need logs. Please open a ticket on github.
Also, was this the case with 0.7.8 as well?
Tried that and didn’t work, thnx anyway. I’ll try to tinker with it myself to get it working. don’t worry about it. and thnx for PM4K
