Just got PM4K set up on an UGOOS AM6B+ and it’s been awesome so far. Just one minor issue, not sure if I’m doing something wrong or if it’s a conflict of some sort.
When I set CoreELEC to launch directly to the “Settings” pane with this setting instead of the default of the “Home window” pane, the PM4K setting to “Start Plex On Kodi Startup” is no longer honored on startup. Navigating back to the “Home window” will then launch PM4K.
Am I setting something wrong, or is this a conflict/bug of sorts between CoreELEC and PM4K?
It’s a minor gripe, but I’m really only exiting out of PM4K to get to the core settings pane, so it would be nice if this was working nicely together. Not exactly sure who to raise the issue to.
This is correct. PM4K only autolaunches from Home views, as it can never really know whether you want it to autostart while browsing something like settings, or not.
That’d be great! A minor thing no doubt, but it does save a few button presses for people who view their device as a PM4K box, should they ever need to exit out and tinker with settings.
