PM4K / PlexMod for Kodi (18, 19, 20, 21, 22+)
Hmm I only see network related errors in your log. Can you get me a fresh one from after a reboot?
log-2025-04-23-15.17.32.zip (365.7 KB)
here
I made another one because debug was disabled in pm4k
log-2025-04-23-15.22.55.zip (317.6 KB)
When I launch an add-on in Kodi, the most recently launched add-on is displayed first. This isn’t the case with the Plex add-on. How can I change this?
Hey Panni, love the add-on. Any chance on allowing us to pick whatever colour we want for the background of Plex using HTML color codes?
Yes: Advanced ‐ AddonSettings Ā· pannal/plex-for-kodi Wiki Ā· GitHub
I can’t see any debug output in that log, sadly. Only an old crash log.
I have a bug report for the latest version of your software:
I tried the music player with my Premium Music Plex library.
I appreciated having both the cover and the background image of a song/interpret/album. Nice.
But when changing titles (I just shuffled the complete library), it stopped changing the background image from time to time. If you need me to guess the reason. If the new song (interpret) has no background image in Plex, still the old image of the last interpret gets used instead of an ā€œemptyā€ background.
Very likely true.
I meant choosing our own custom colours and not just the preset ones.
You can. Set any color in there, then edit your userdata/addon_data/script.plexmod/settings.xml and change background_colour to the one you want.
Does anyone have any idea how I can fix this?
Just set up PM4K on an Ugoos Am6B+ with CoreElec. Coming from a Shield. On the Shield when skipping back or forward with left and right arrows response was immediate but in PM4K there is a delay. Is this just a Kodi limitation? Is there any way to change this and make it instant within settings? Thanks.
Does PM4K support any kind of deeplinking? For example, using a URL containing the Plex ratingKey to automatically open the preplay screen or (ideally) immediately starting playback of the item?
Not right now, no. As we’re only connecting to one server at a time, that’s hard to do. Ratingkeys are not exclusive, so we’d have to fix that, first.
App works great but most of the actor thumbnails are blank. I do see them on the PMS server just fine. Any ideas?
Edit: Just tried refreshing metadata in PMS for the library, and that seems to have fixed it.
Anyone else having this seeking problem in coreelec? even using the ā€œuse alternate seekā€ option.
In the video I press forward only 3 times.
VĆ­deo - Google Fotos
Edit: From what I understand, he plays this game of playing forward and back about 5 to 10 seconds so as not to have audio synchronization problems that happen when using ā€œalternate seek offā€
You can try ā€œuse alternate seekā€ (disable or enable)
Thanks. Where is this setting? I can’t find it. Is it in Kodi or PM4K?
Install PM4K on top of CoreElec. I do not get any posters and nothing runs. The logs seem to show a strange URL. Note the IP with dashes. Is this normal? Or just how the logfile shows them.
It is located at 10.10.140.10 and dual boot eMMC Plex App has no issues on WiFi either came right up.
Am I missing a setting? The media all automatically popped in when I signed in, but can’t see posters or do anything with them.
THANKS so much for anyone who takes time to set me straight.
2025-04-27 18:15:23.231 T:4129 error : CCurlFile::Stat - https://10-10-140-10.2effa0fa2c794cfc87848xxxxxxxxxxxxx.plex.direct:32400/photo/:/transcode?url=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F51689%2Fthumb%2F1744883949&width=244&height=361&minSize=1&X-Plex-Token=iLdNmC7ew_UP64so1Q6J Failed: Couldn’t resolve host name(6)
Im having the same issue. Would appreciate any help!
It was working without a problem, but now I run the app and it just gives me a blank screen which loads nothing. All I can see above is my profile and a ā€œNo Servers Foundā€ message. It’s completely broken for me. Any help appreciated.
PS: this is now happening both on the device storage, and on a Kodi image I’m running out of an SD card in the Ugoos AMB6+.
