PMP Embedded
Whats the latest with PMP Embedded?
Its still on 2.2, but I see PMP is up to 2.8 now.
Another question my NUC7i3 struggles with 4k, are there any better options?
I saw the new NUC Hades Canyon, although expensive, I’m all for paying and getting something good.
Only thing is I dont think it has an IR receiver.
Is there anything else now? Or wait for NUC8 series?
  • crickets *
I actually have been building it myself. I just set it to build every day with and upload to my onedrive account.
You can find it here: https://1drv.ms/f/s!Am5k0gWuPRCRorNJhcvUGWqKwVU92g
For the IR receiver part, I’ve been using a FLIRC. It works well with RPi or intel embedded.
@Lamarios is there an easy way to update to your build?
Just replace some files somewhere?
we have released test builds. they are not official yet, because they still need a few things fixed.
But you can check those still : https://nightlies.plex.tv/public-test/plexmediaplayer/embedded-testing/
Awesome, thanks LongChair
Hello, is there any update on PMP Embedded support? I am thinking of buying a newer Intel NUC in order to take advantage of PMP Embedded again (have audio issues with Kaby Lake), but want to make sure this is still a “reasonably” supported option. Thank you!
