PMP on Intel NUC
I have a question about Plex Media Player for Plateformes intégrées, version for Intel NUC.
Does the Version 1.3.11.758-4be89b5c from October 26, 2017 is the latest version? 0_o
It might be time to update it right?
have a look here https://nightlies.plex.tv/public-test/plexmediaplayer/embedded-testing/latest/
Serious question: How are the current nightlies for embedded? I have to admit, I’ve kind of given up and moved to other solutions. But it was so nice when it worked well on the NUC.
Is That an official version ? Or it’s beta version ?
Why Plex dosen’t upgrad his website ?
I do quite a bit of PMP testing and that version is fairly stable. However due to its base of LE8.2, it does not supported post Skylake NUCs well.
Thank you for your work !
However, Plex doesn’t work on it ? The project for NUC and raspberry Pi would be abandoned ?
I was looking at getting a NUC7CJYH, do you know if that works well with the nightly builds. Dont suppose you know if its possible to run PMP and other apps on the same NUC? want to install Domotz if possible alongside PMP.
TIA
If you install the Windows version. Embedded needs to be rebased to LE9 in order to support the Gemini Lake.
