PMS 1.13.4.5271 on Synology DSM 6.1.7-15284 Update 2
I just tried to upgrade PMS from 1.13.4.5251 to 1.13.4.5271 on my Synology running DSM 6.1.7-15284 Update 2 and it errors out when trying to manually upgrade PMS saying:
This package is not supported on the platform of Diskstation or is incompatible with the current DSM version.
Regards,
Dennis
Upgraded to PlexMediaServer-1.13.4.5251-2e6e8f841-x86 on Synology DSM 6.2-23739 Update 2 today. PLex not able to execute. Doesn’t come up, deleted and re-installed, no solution, and downgrading not possible.
I’m getting this exact problem. I’m trying to upgrade a 32bit PMS to 1.13.4.5271 onto a 32bit Synology (1511+) running 6.1.7-15284u2 and get the incompatible version error message.
I’m not sure what downgrading would do in my instance.
Solved by DSM 6.2 Update 2 Announcement
Not seeing this apart from the usual release notes.
What am I missing?
Found it. Seems we need to run the x64 version of Plex even though we’re on a x86 DSM.
It looks like the link shown on PMS is not the right version :confused: i was updating today over the link provied on my PMS page and after the update i wasn’t able to start the server. Then i was downloading it on the Plex.tv website for Synology x64 and everything is ok.
