PMS 1.15.0.659 Download Offline
I am trying to download PMS 1.15.0.659 via the Linuxserver.io docker, and it seems that the download link is offline?
Atempting to upgrade to: 1.15.0.659-9311f93fd
https://downloads.plex.tv/plex-media-server/1.15.0.659-9311f93fd/plexmediaserver_1.15.0.659-9311f93fd_amd64.deb:
2019-02-07 17:20:11 ERROR 404: Not Found.
I am also unable to find the download directly via the plex.tv/downloads page, for all platforms I see only 1.14.1.5488 (Plex Pass is toggled on).
The downloads page seems to having some issues, you can find the current links here:
The downloads page is having ā€œdifficultiesā€ :joy:
The folks are fixing it. :crossed_fingers:
Still not working today so its taking a quite a while to fix the download problem.
Have you downloaded directly at plex.tv/downloads?
Plex Pass members will now see 1.15.0.659
I just did, even tried a private browser just now and still get 1.14.1.5488-cc260c476 December 14, 2018
also, the way the forum parses the link it changes it to:
http://plex.tv/downloads?_ga=2.144…(more numbers) and it breaks but when typing just the start it redirects to:
https://www.plex.tv/media-server-downloads/
and again still 1.14…
Also still seeing 1.14. Edge, Chrome, update script on Ubuntu Server. VPN to Finland from United States with Edge in InPrivate Window, all 1.14.1.5488
The downloads site it running ā€˜split’ right now.
If the browser is not working, I need to know where the reference point (vpn exit if using one) is.
Scripts are unlikely to work because the URLs are non-standard during this beta.
There is no ā€˜automatic’ mode right now.
Using manual download from plex.tv/downloads is needed.
I’ve got the same issue; switching plex pass downloads on/off seems to make no difference. Flushing caches, changing browser, logging out + in - it just shows the December 14 1.14.1.5488 builds for me. I can see a notification link when connecting to my server but that link - downloads/latest/1?channel=8&build=linux-ubuntu-x86_64 blahblahblah doesn’t work if you try and just wget it, so I can’t really grab the URL and shove it onto my server.
I presumed it was a problem with the build resulting in it getting pulled or something.
Only my Ubuntu Server used plexupdate which has worked for years without issue. All other tests I did was with plex.tv/downloads. It is still broken.
Edit: Just tried Chome Incognito no VPN (Ohio, US). VPN with Hong Kong, Denmark, US California, Australia Sydney, and Singapore. All show 1.14
Still not there - that is fine though i’m having the same crashing issues with .659 as the previous on win 10
I’m getting the same issue when docker from linuxserver.io when it tries to pull the image (1.15.0.659).
I tried to download the file manually with no VPN and I’m still only getting 1.14 from December.
If you are using Linux https://github.com/mrworf/plexupdate has been updated and works now.
I’m having the same issue. Switch from Plex Pass to not makes no difference, i.e. still showing the Dec-18 release. I’m on MacOS and trying to download the latest server for Synology.
