PMS 1.23.0.4497 Transcoder no longer transcodes anything
Sorry about that. I’ve attached my logs here.
Plex Media Server Logs_2021-05-07_20-43-36.zip (537.5 KB)
@mushuwushu
Thank you for the logs.
I see where the transcoder is failing with a seg fault. That’s VERY odd.
I just did a test last night for Docker which was successful.
May I get a 2 minute sample of that video file so I may retest/recreate here?
May 07, 2021 20:41:54.014 [0x149d98bf8b38] DEBUG - [Transcode] Subtitles: Found a candidate subtitle language [eng] for a foreign film
May 07, 2021 20:41:54.014 [0x149d98bf8b38] DEBUG - [Transcode] Audio Stream: 45410, Subtitle Stream: 45411
May 07, 2021 20:41:54.015 [0x149d98bf8b38] DEBUG - [Transcode] Cleaning directory for session kn7tgerb1cms36f9gtzkhdoi ()
May 07, 2021 20:41:54.016 [0x149d98bf8b38] DEBUG - [Transcode] Starting a transcode session kn7tgerb1cms36f9gtzkhdoi at offset -1.0 (state=3)
May 07, 2021 20:41:54.018 [0x149d98bf8b38] DEBUG - [Transcode] [Universal] Using local file path instead of URL: /data/Movies/The Courier (2021)/The.Courier.2020.1080p.WEBRip.DD5.1.x264-CM.mkv
May 07, 2021 20:41:54.019 [0x149d98bf8b38] DEBUG - [Transcode/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/fa235d6-3855-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxj' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'h264' '-codec:1' 'ac3' '-ss' '95' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/data/Movies/The Courier (2021)/The.Courier.2020.1080p.WEBRip.DD5.1.x264-CM.mkv' '-filter_complex' '[0:0]scale=w=720:h=404[0];[0]format=pix_fmts=yuv420p|nv12[1]' '-map' '[1]' '-codec:0' 'libx264' '-crf:0' '21' '-maxrate:0' '884k' '-bufsize:0' '1768k' '-r:0' '23.975999999999999' '-preset:0' 'veryfast' '-x264opts:0' 'subme=6:me_range=4:rc_lookahead=10:me=hex:8x8dct=1' '-filter_complex' '[0:1] aresample=async=1:ocl='\''stereo'\'':rematrix_maxval=0.000000dB:osr=48000[2]' '-map' '[2]' '-metadata:s:1' 'language=eng' '-codec:1' 'libopus' '-b:1' '162k' '-map' '0:2' '-metadata:s:2' 'language=eng' '-codec:2' 'copy' '-map' '0:t?' '-codec:t' 'copy' '-f' 'segment' '-segment_format' 'matroska' '-segment_format_options' 'live=1' '-segment_time' '1' '-segment_header_filename' 'header' '-segment_start_number' '0' '-segment_list' 'http://127.0.0.1:32400/video/:/transcode/session/kn7tgerb1cms36f9gtzkhdoi/c2bd82c2-5fc8-4de1-ae76-566a1e14aeea/seglist?X-Plex-Http-Pipeline=infinite' '-segment_list_type' 'csv' '-segment_list_unfinished' '1' '-segment_list_size' '5' '-segment_list_separate_stream_times' '1' '-avoid_negative_ts' 'disabled' '-map_metadata:g' '-1' '-map_metadata:c' '-1' '-map_chapters' '-1' 'chunk-%05d' '-start_at_zero' '-copyts' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/kn7tgerb1cms36f9gtzkhdoi/c2bd82c2-5fc8-4de1-ae76-566a1e14aeea/progress'
May 07, 2021 20:41:54.019 [0x149d98bf8b38] DEBUG - [Transcode/JobRunner] Jobs: Starting child process with pid 587
May 07, 2021 20:41:54.026 [0x149d98b56b38] DEBUG - Request: [127.0.0.1:34260 (Loopback)] PUT /video/:/transcode/session/kn7tgerb1cms36f9gtzkhdoi/c2bd82c2-5fc8-4de1-ae76-566a1e14aeea/progress?status=startup (16 live) Signed-in Token (laurenceco) (range: bytes=0-)
May 07, 2021 20:41:54.026 [0x149d99551b38] DEBUG - Completed: [127.0.0.1:34260] 204 PUT /video/:/transcode/session/kn7tgerb1cms36f9gtzkhdoi/c2bd82c2-5fc8-4de1-ae76-566a1e14aeea/progress?status=startup (16 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
May 07, 2021 20:41:54.045 [0x149d98bd5b38] DEBUG - Request: [127.0.0.1:34260 (Loopback)] PUT /video/:/transcode/session/kn
This only happens on the beta version though. I’m not sure if this is specifically related to this video as I can’t transcode any videos I have. I’m doing software cpu transcode only.
Still want a sample video?
@mushuwushu
yes please. I will test/recreate here with software transcoding
@ChuckPa
I somehow was able to trace the cause of my transcoder problem. Having my transcoder settings to “make my cpu hurt” would cause this issue and any other settings would work fine.
I’ve tested on a new docker on the same unraid server (intel i7-7820x cpu) and on another unraid server (intel i7-4770)
On a new docker the issue remains but on the other server it doesn’t cause any issue.
