can someone confirm this is fixed for Celeron J* series? e.g. Synology DS1019+
Regardless of which J series:
Upgrade PMS
This post will give you and tell you how to switch to the i965 driver
- You must make certain to enable all the transcoding options again.
Thank you, problem fixed, followed the instructions. Had a two other problems.
in Logs: EAE timeout! EAE not running, or wrong folder?
Fixed inotify, echo 16384 | sudo tee /proc/sys/fs/inotify/max_user_watches
and Deleted the Codecs directory.
ChuckPa
45
This will only last until next reboot.
Permanent fix is here:
system
Closed
46
