Latest build 7100 not transcoding on Intel QSV
Server Version#:1.32.2.7100
Player Version#: Multiple devices
Hi all,
I’ve found an issue with the latest build 7100 and the couple before it not allowing transcode on my server.
My server is…
CPU - i7-3770
RAM - 16Gb
HDD- in excess of 60Tb
Operating System - Ubuntu MATE 20.04.6LTS
I was just wondering if anyone else has this issue using the iGPU with QuickSync on the latest builds? I’ve returned back to build 6999 which the HW transcoding works without any issues.
I know the CPU is old, but I don’t have any 4k video and 99% of the files I’ve got are 720p with some older TV shows in 480p and a few in 1080p.
I can supply logs if needed, I just want to get this working on the latest version.
Many thanks in advance…
Dave
exactly the same problem here on a i7-3770. Hoping that someone addresses it …
Same issue on debian with an i7-4770s. No hw transcode on latest public, even tried a few prev beta builds. Last to work was prev public.
Hey both, glad it’s not just myself that has this issue, I thought I was going crazy. I wonder if @ChuckPa can help she’d light on the issue?
Dave
Same for me
CPU: i7-4790K
OS: Ubuntu 18.04.6
DEBUG logs ZIP which captures the problem please.
Also please tell me if Preferences.xml has any transcoding customization(s).
( FYI: “Me too” isn’t actionable. )
Best additional info with logs: → Native, VM, or container
Hi @ChuckPa. I can provide logging demonstrating success under 1.32.1.6999 and failure under 1.32.2.7100, if you’ll allow me to PM them to you.
The environment this server is running under is:
Ubuntu 22.04.2 LTS
Intel Atom x5-Z8300 (yeah, yeah, I know, but it works for this server’s use-case)
Native, no VMs or Docker containers involved
No customizations to Preferences.xml
I have another server, with a Celeron N5105 (Jasper Lake) processor, which is not affected. It’s OS environment is not the same however (Pop_OS! 22.04 LTS), so it’s not apples to apples.
@pshanew
Processor does not have QSV
I think we’ve had this conversation before, and it does (they just don’t use the marketing name “Quick Sync Video” on their earlier, low-end stuff). Please see the “Other Processors” section in the first table of this document (they don’t call it out specifically as QSV):
And, more important than that, it works. On .6999 and earlier releases. I’ll send the logs, but if you’d prefer to wait for others’ logs, no problem.
In case it provides further clarity, here’s the output of vainfo on the system:
error: can't connect to X server!
libva info: VA-API version 1.14.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_14
libva error: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
libva info: va_openDriver() returns 1
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_1_8
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.14 (libva 2.12.0)
vainfo: Driver version: Intel i965 driver for Intel(R) CherryView - 2.4.1
vainfo: Supported profile and entrypoints
      VAProfileMPEG2Simple            :	VAEntrypointVLD
      VAProfileMPEG2Simple            :	VAEntrypointEncSlice
      VAProfileMPEG2Main              :	VAEntrypointVLD
      VAProfileMPEG2Main              :	VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline:	VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:	VAEntrypointEncSlice
      VAProfileH264Main               :	VAEntrypointVLD
      VAProfileH264Main               :	VAEntrypointEncSlice
      VAProfileH264High               :	VAEntrypointVLD
      VAProfileH264High               :	VAEntrypointEncSlice
      VAProfileH264MultiviewHigh      :	VAEntrypointVLD
      VAProfileH264MultiviewHigh      :	VAEntrypointEncSlice
      VAProfileH264StereoHigh         :	VAEntrypointVLD
      VAProfileH264StereoHigh         :	VAEntrypointEncSlice
      VAProfileVC1Simple              :	VAEntrypointVLD
      VAProfileVC1Main                :	VAEntrypointVLD
      VAProfileVC1Advanced            :	VAEntrypointVLD
      VAProfileNone                   :	VAEntrypointVideoProc
      VAProfileJPEGBaseline           :	VAEntrypointVLD
      VAProfileJPEGBaseline           :	VAEntrypointEncPicture
      VAProfileVP8Version0_3          :	VAEntrypointVLD
      VAProfileVP8Version0_3          :	VAEntrypointEncSlice
      VAProfileHEVCMain               :	VAEntrypointVLD
Thank you very much for this.
I’ve chatted with the Engineer.
She’s seen the logs and will most likely be taking over here to figure out the issue.
Per her request, I’ve opened an internal ticket.
Interesting. I wonder.
Same issue to me,
Intel(R) Celeron(R) CPU J3355
vainfo
vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 22.3.1 ()
VAProfileH264Main : VAEntrypointEncSliceLP
VAProfileH264High : VAEntrypointEncSliceLP
VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
But I think is related with the internal ticket i915,
Not working,
<Variants>
<Variant id="316a2013-04e2-4510-b022-75bc2f0dbce3" targetBitrate="1422" context="streaming" sourceVideoCodec="h264" sourceAudioCodec="aac" videoDecision="transcode" audioDecision="copy" protocol="hls" container="mpegts" videoCodec="h264" audioCodec="aac" audioChannels="2" transcodeHwRequested="1" transcodeHwFullPipeline="0">
<Media id="814710" origin="livetv" timeStamp="1684848163.1094799" uuid="617baef1-5409-4d32-8d13-c93260dc8ed2" audioChannels="2" audioCodec="aac" bitrate="1354" container="mpegts" height="404" protocol="hls" videoCodec="h264" videoFrameRate="PAL" videoResolution="SD" width="720" selected="1">
<Part deepAnalysisVersion="6" id="829390" bitrate="1354" container="mpegts" height="404" protocol="hls" width="720" decision="transcode" selected="1">
<Stream bitrate="1290" codec="h264" displayTitle="1080i (H.264)" extendedDisplayTitle="1080i (H.264)" frameRate="25" height="404" id="1514822" streamType="1" width="720" decision="transcode" location="segments-av" />
<Stream audioChannelLayout="stereo" bitrate="64" bitrateMode="cbr" channels="2" codec="aac" displayTitle="Portugu&#234;s (HE-AAC Stereo)" extendedDisplayTitle="Portugu&#234;s (HE-AAC Stereo)" id="1514823" language="Portugu&#234;s" languageCode="por" languageTag="pt" profile="he-aac" requiredBandwidths="64,64,64,64,64,64,64,64" samplingRate="48000" selected="1" streamType="2" decision="copy" location="segments-av" />
</Part>
</Media>
</Variant>
</Variants>
Working
<Variants>
<Variant id="efa2bf0e-3e07-4e9f-b8fe-7e019b0f45d3" targetBitrate="2810" context="streaming" sourceVideoCodec="h264" sourceAudioCodec="aac" videoDecision="transcode" audioDecision="copy" protocol="hls" container="mpegts" videoCodec="h264" audioCodec="aac" audioChannels="2" transcodeHwRequested="1" transcodeHwDecoding="vaapi" transcodeHwEncoding="vaapi" transcodeHwDecodingTitle="Intel (VA API)" transcodeHwEncodingTitle="Intel (VA API)" transcodeHwFullPipeline="1">
<Media id="814711" origin="livetv" timeStamp="1684860473.3308132" uuid="8186ad67-e7e6-4817-a484-837ecf126a95" audioChannels="2" audioCodec="aac" bitrate="2677" container="mpegts" height="404" protocol="hls" videoCodec="h264" videoFrameRate="PAL" videoResolution="SD" width="720" selected="1">
<Part deepAnalysisVersion="6" id="829391" bitrate="2677" container="mpegts" height="404" protocol="hls" width="720" decision="transcode" selected="1">
<Stream bitrate="2613" codec="h264" displayTitle="1080i (H.264)" extendedDisplayTitle="1080i (H.264)" frameRate="25" height="404" id="1514824" streamType="1" width="720" decision="transcode" location="segments-av" />
<Stream audioChannelLayout="stereo" bitrate="64" bitrateMode="cbr" channels="2" codec="aac" displayTitle="Portugu&#234;s (HE-AAC Stereo)" extendedDisplayTitle="Portugu&#234;s (HE-AAC Stereo)" id="1514825" language="Portugu&#234;s" languageCode="por" languageTag="pt" profile="he-aac" requiredBandwidths="63,63,63,63,63,63,63,63" samplingRate="48000" selected="1" streamType="2" decision="copy" location="segments-av" />
</Part>
</Media>
</Variant>
</Variants>
if needed logs let me know
Use this.
Do not upgrade until I’ve had chance to verify.
Anyone using Docker can manually pull this specific version-hash
With 1.32.2.7100 also HW transcoding stopped working on my Synolgy DS218+ (DSM 6.2.4, Intel Celeron J3355, 64Bit). Rolling back to 1.32.1.6999 did the trick for now.
I posted the 6999 binaries in the Syno Forum :slight_smile:
Thanks. Downgrade to 6999 worked. I’m willing to send zipped logs direct if they would help.
CPU: i7-4790K
OS: Ubuntu 18.04.6
Native & Docker*
Docker image: lscr.io/linuxserver/plex:latest
No transcoding customizations
vainfo:
error: XDG_RUNTIME_DIR not set in the environment.
libva info: VA-API version 1.1.0
libva info: va_getDriverName() returns 0
vainfo: VA-API version: 1.1 (libva 2.1.0)
vainfo: Driver version: Intel i965 driver for Intel(R) Haswell Desktop - 2.1.0
Docker users can ‘pull’ the 6999 build by including version-hashcode
plexinc/pms-docker:1.32.1.6999-91e1e2e2c
I’ll also grab binaries for those who need them
Folks
The engineer has asked me to ask you to confirm this resolves the lack of HW transcoding on older -3xxx (workstation/server) and newer -4xxx CPUs (NAS)
This is an Engineer’s build (wacky numbers)
https://drive.google.com/file/d/1NzThv1IaWrJY8eI8ysYHOZwARbv7_FFf/view?usp=sharing
This build appears to have resolved the issue on my system:
I also tested with a 1080i MPEG2 transcode and it worked as well.
Thanks very much for the speedy resolution!
Server DEBUG logs to confirm please ?
(so I can :white_check_mark: the box)
@ChuckPa - The requested logs have been messaged to you. Thanks!
