Posting this in Plex Pass discussion in the hopes that it gets more attention from Plex.
I finally upgraded my PMS install, after a holding pattern on 1.4.x, due to the Plex.tv client bug hammering old servers (this).
Like many others–a few Reddit threads, threads here on the Plex forums–I now have increased reports of bad quality and buffering from the handful of friends and family that use my server, where no problems existed before. I strong suspect there is some bad math happening on the Plex server side of things when it comes to buffer/bitrate calculation.
I am running 1.9.5.4339.
One indication of bad math is newly-incorrect “Limit Remote Stream Bitrate” calculations. Here’s a concrete example:
With my server set to 4Mbps stream limit:
And content at ~2.6Mbps, as seen by the PS4 Plex client:
The server is sending a massively low quality stream:
(It’s also visually quite evident that it’s a low-bitrate stream without checking PlexPy)
With higher-bitrate content, like movies, nearly everyone is reporting that their Plex client starts continuously buffering at 720p bitrates (3 or 4Mbps). This was absolutely not present in 1.4.x. My best guess is that Plex is doing buffer/throttle/whatever calculations wrong and just not encoding enough content for the bitrate/transfer that’s actually going out on the wire.
I doubt my server/network are a factor. They haven’t changed, and also I run Plex in a VM with 14 available cores, have transcoding temp directory set to a 16GB ramdisk, etc etc. It’s pretty far into overkill territory.
It was not hard for me to replicate these issues at home–I set up an old router to go through a VPN, plugged the PS4 into it, and started seeing some of the issues that people outside my network are seeing. Are Plex engineerings seriously not testing these use cases? It’s very, very frustrating that upgrading Plex introduces new issues (and the only reason I had to upgrade was because of the Plex.tv client bug).
I’m happy to extract whatever server/transcoding log files can illuminate the issue, if it helps. From other threads I’ve seen here, though, I’m very likely just yelling at the wind, and Plex will launch some kind of fantasy football integration long before they address issues like this :neutral:
