PMS Broken
Server Version#: 1.41.3.9314
Player Version#: 10.26.0.2578
Tuner Make/Model: WinTV
Guide/Lineup name: Local
Using XMLTV?: No idea what that is
Channel number/Name: All
Well this was going to be a post complaining that after adding my tuner and completing the channel scan, I got an error that the tuner was unavailable for every channel.
I finally had it, and did a factory reset on the Shield TV Pro, and spun everything up from scratch. Well, now PMS won’t start. It doesn’t even show in the app so I can’t tell it to start or stop.
I don’t know how anyone says Shield TV Pro is the best way to host PMS when it doesn’t work from scratch. What do I have to hack to get the stupid thing to work?
This is probably the 15th time I’ve rebuilt PMS on this device, and I finally moved my main instance to Windows, but unfortunately I have no reasonable method to move my TV tuner… so I need Shield to at least run a simple PMS with tuner with no libraries.
Are you able to run the Android tv player on the Shield and does it recognize the capability to run/enable the server?
https://support.plex.tv/articles/221099988-setting-up-and-managing-plex-media-server-on-nvidia-shield/
I’m not aware of anyone saying this. The Shield is a great player, though.
