PMS not running on Nvidia Shield TV Pro after upgrade to PMS 1.19.3.2764
Server Version#:1.19.3.2764
Player Version#:8.0.1.17410
After upgrading PMS to 1.19.3.2764 on my Nvidia Shield TV Pro last night I cannot get PMS to run. When I check it within the setting of the Plex client it shows stopped and if I attempt to start it the “starting” windows comes up for about 20 seconds then disappears and the state is still stopped. I have tried clearing the cache for the PMS app. I have restarted, shutdown/rebooted the Shield several times and even removed power for a couple of hours and rebooted it, all to no avail.
Anyone else with a Shield having this problem? Any suggestions?
Blueskies, Paul
Mounted the Shield storage to my PC and found the logs at \\shield\internal\Plex Media Server\Logs\Plex Media Server.log:
May 13, 2020 08:30:00.252 [29747] INFO - Plex Media Server v1.19.3.2764-ef515a800 - NVIDIA SHIELD Android TV foster - build: android-aarch64 unknown - GMT 10:00
May 13, 2020 08:30:00.252 [29747] INFO - Android version: 9, language: en-US
May 13, 2020 08:30:00.252 [29747] INFO - Processor Unknown architecture
May 13, 2020 08:30:00.253 [29744] DEBUG - BPQ: [Idle] -> [Starting]
May 13, 2020 08:30:00.258 [29744] ERROR - Unable to open named mutex 9334581e-7251-4ef7-a8ec-5bfe8e89ff68 with option 1: Function not implemented
May 13, 2020 08:30:00.259 [29744] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=1
May 13, 2020 08:30:00.261 [29744] INFO - SQLITE3:0x7fffffff, 283, recovered 227 frames from WAL file /data/user/0/com.plexapp.mediaserver.smb/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
May 13, 2020 08:30:00.360 [29744] DEBUG - Running migrations. (EPG 0)
May 13, 2020 08:30:00.495 [29744] DEBUG - ChangestampAllocator: initialized to 1886587
May 13, 2020 08:30:00.495 [29744] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=1
May 13, 2020 08:30:00.497 [29744] INFO - SQLITE3:0x7fffffff, 283, recovered 194 frames from WAL file /data/user/0/com.plexapp.mediaserver.smb/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal
May 13, 2020 08:30:00.504 [29744] DEBUG - Running migrations. (EPG 0)
May 13, 2020 08:30:00.521 [29750] DEBUG - Codecs: Downloading current version of msmpeg4v3 decoder
May 13, 2020 08:30:00.521 [29750] INFO - CodecManager: obtaining decoder ‘msmpeg4’
May 13, 2020 08:30:00.521 [29750] DEBUG - Relay: read 0 cached entries from hosts file
May 13, 2020 08:30:00.521 [29750] DEBUG - HTTP requesting GET https://plex.tv/api/codecs/msmpeg4v3_decoder?build=android-aarch64-standard&deviceId=2f2db3b0-d900-4f2a-ac77-1d3d36a52135&oldestPreviousVersion=1.4.3.3433-03e4cfa35&version=99c90e0-3095
May 13, 2020 08:30:00.543 [29744] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
May 13, 2020 08:30:00.543 [29744] DEBUG - HttpServer: Listening on port 32400.
May 13, 2020 08:30:00.543 [29744] DEBUG - HttpServer: Listening on port 32401.
May 13, 2020 08:30:00.551 [29755] DEBUG - Grabber: Cleaning up orphaned grabs.
May 13, 2020 08:30:00.553 [29755] ERROR - Thread: Uncaught exception running async task which was spawned by thread 29744: std::bad_cast
May 13, 2020 08:30:00.553 [29744] ERROR - Error: Unable to set up server: std::bad_cast (St8bad_cast)
All 6 copies look identical apart from times being 20 seconds or so different… I can zip the Logs folder and post it if that helps?
Any ideas how to get this working without starting again?
Blueskies, Paul
