Server Version#: 1.16.3.1402
Player Version#: unsure, but no issues.
So as it says, for the last few months, the server crashes and the tray icon disappears sometime during the night, and I think during maintenance within Plex. I tried looking for conflicting .dll files that may conflict, to no avail. I have everything up to date, and the server runs fine normally. I have attached the logs, I’m not technical enough to understand them unfortunately. Any help or insight is greatly appreciated, thanks!
Your logs roll over, due to you have enabled verbose logging
Switch that off, restart PMS, and wait for next time it happens, then re-upload new set of logs
Sadly, there’s nothing in the logs, indicating any crash
When said though, you have some shows not following naming std
BBC Life 720p bad title, and missing season xx folder
Same for other BBC shows
Next step would be to go into settings, and disable all scheduled tasks, to see if they are the ones causing it, as well as check Windows Event log if that contains any clues
OKay last time before I roll back. The server was running well for 3 days/nights with no crashes, but it crashed last night some time. Last logging attempt, if you don’t mind, thank you much!
I am still on PMS 1.15.8.1198 and don’t trust the new versions until someone can confirm a bug that has been mitigated. PMS 1.15.8.1198 has been running since my last reply. My scheduled tasks occur between 2am and 5am. All tasks enabled except “Update all libraries during maintenance”. I think I have even manually successfully done a database optimisation once, or twice since my last reply.
It could be that the PMS coding has been changed in versions 1.16.xx for library scanning?
Since the 2 new updates since my original posting, it seems to have been resolved. I have most scheduled tasks running at this point for a week now, with no crashes.
I am hoping it was just a bug in the particular version.
Plex is still crashing on me every 24 hours. Version 1.16.5.1488
Back dating to Version 1.16.2.1321 it runs perfect!
Any help is appreciated. Plex Media Server Logs_2019-08-22_20-25-58.zip (6.6 MB)
@dane22 when you get a moment do you mind taking a look at my logs and seeing why my server randomly crashes. The update causes it every 24 hours. Backdating to 1321 seems to just be random(days or weeks) the icon will disappear and I have to restart the server. Running Windows 10 fully updated, tuners are fully updated also. Thank you!
