HI all I"ve noticed over the past few released my PMS serivce keeps on Crashing causeing people not able to use my server. Plexpy advises me when it’s down and I have to go and restart the service on My Qnap TVS-882 I’m running 1.11.0.4666 and was wondering if there might be a fix or something for these crashes or have other people experienced the same issue. Thanks in advance.
Yep mine crashed on my local laptop and web access I use solely for myself during recording a typical station. This time it crashed simply trying to stop the recording by canceling it as there is no other way to do so while one other program was still recording. The thing is the sever and tuner were still up running but I could not access them. So it is not only your problem. PLEX has a ways to go to make this product stable me thinks.
May I suggest you downgrade to the most recent (stable) version of PMS v1.10.1.4602, v1.11.0.4666 is beta and as such there could be problems/bugs that need to be flushed out. See if that helps. If that does not fix your problems then I have seen it suggested people disable items in maintenance so give that a try.
Faulting application name: Plex Media Server.exe, version: 1.11.0.4666, time stamp: 0x5a447a07
Faulting module name: Plex Media Server.exe, version: 1.11.0.4666, time stamp: 0x5a447a07
Exception code: 0xc0000005
Fault offset: 0x000265db
Faulting process id: 0x2968
Faulting application start time: 0x01d38c7ae650f492
Faulting application path: C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Server.exe
Faulting module path: C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Server.exe
Report Id: eca8c129-3dfb-4ec8-b1de-c9d2fe32aff7
Faulting package full name:
Faulting package-relative application ID:
Like I posted above and same suggestion to you, Please downgrade to the latest (stable) version and see if it helps. You are also running a beta not the stable version…
Had same issue, dropped back to 4602 and deleted contents of Codecs folder. Now running again.
Once I upgraded to the latest release the freezing has stopped and so has the crashing.
